question about hondata ecu
Old Jul 24, 2003 | 09:38 AM
Nextelbuddy's Avatar
Default question about hondata ecu
well since i h ave a gsr motor now with the butterfly intake manifold i now have 2 ecus, my chipped p28 which has the jun progrma and also a obd1 p72 for the gsr motor. i hav my turbo kit but i have to give up one of my ecu's to the shop so i can get my hondata ecu. my question is if i give up my obd1 p72 ecu do i need to get a hondata p72 ecu that will run the butterflies? or are all the hondata ecus' p28's? i dont want to get a hondata p28 ecu thats not going to open up the butterflies in the manifold. any answers?
Old Jul 24, 2003 | 09:45 AM
DOHCtorTHRUST's Avatar
Default Re: question about hondata ecu (nextelbuddy)
i havent read anything about hondata openening butterflies... i know that hondata make wonders but havent heard anything about that.... i personally think you should run the p72 to open the butterflies up....
Old Jul 24, 2003 | 09:50 AM
Default Re: question about hondata ecu (DOHCtorTHRUST)
i thoguht that hondata could chip and socket your p72 ecu so that it will run hondata and still open up the buterflies. i thoguht it was liek this: b16,type r, and gsr motors with skunk 2 manifold motors use p28 ecus since those motors dont have butterflies but gsr motors with stock dual runner manifold need to use the p72 still? am i right?
Old Jul 24, 2003 | 10:41 AM
ok i found it on hondatas website. it clearly says that if u dont use a p72 ecu with the gsr motor that u will lose the ability to control the secondary intake runners. basically saying that im going to need to get my p72 ecu chipped and socketed by hondata if i dont want to lose control of the secondary runners.
Old Jul 24, 2003 | 10:43 AM
ce's Avatar
ce
Either have them put the chip in your p72 or do it yourself it's very easy.Then you can control the secondary runners ..
Nextelbuddy
Jul 4, 2004 03:28 PM
TerribleOne
Feb 9, 2004 03:51 PM
Seye
16
Oct 24, 2003 07:25 AM
StinkyTofu
Dec 29, 2002 11:51 PM
