Bye Bye Blue Box, But What's an Alternative?
Old Jul 24, 2003 | 06:16 AM
devonic's Avatar
Default Bye Bye Blue Box, But What's an Alternative?
Well since im getting another motor since i blew 2 piston rings in my current one(compression test was 4 - 65 , 3 - 110 , 2 - 200 , 1 - 200), I want to ditch the blue box since i hear alot of horror stories about it. But what can i use? I have a sohc d16y7/y8 mini me in there now but a complete d16y8 is probably going to be going in there. i have the greddy 15g kit. What can i use as an alternative to the dreaded blue box?
Old Jul 24, 2003 | 06:24 AM
dabrown's Avatar
Default Re: Bye Bye Blue Box, But What's an Alternative? (devonic)
How did you blow your engine while using the Blue Box?
Old Jul 24, 2003 | 06:27 AM
devonic's Avatar
Default Re: Bye Bye Blue Box, But What's an Alternative? (dabrown)
wastegate tube got disconnected, but i dont like the blue box cause it gave me horrible gas mileage...since im putting a new motor in i don't want the blue box doing my management anymore
Old Jul 24, 2003 | 06:28 AM
DBallz's Avatar
V-AFC Hack, Zip's SMC 500, or Hondata.
Old Jul 24, 2003 | 06:29 AM
devonic's Avatar
with the vafc hack, what all do i need?
or hondata?
Old Jul 24, 2003 | 06:34 AM
99lspwr's Avatar
Unless you are running aem or hondata, I would keep the blue box. Once again the blue box is not as bad as everyone makes it out to be... Way better than an fmu set-up, and much more reliable if you plan on boosting over 7-8 psi. I have not had good luck with a fmu set-up over 8 psi.. You could always try an afc-hack
Old Jul 24, 2003 | 06:38 AM
devonic's Avatar
im not sure if im going to do the install on my new engine or if im going to have a shop do it, but if i keep the box and since i only plan on boosting maybe to 8 psi(its at 6psi right now) would it be worth it to have an auto dyno'd?
Old Jul 24, 2003 | 07:00 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
PM sent...I'll take your blue box or trade you for my 12:1 FMU and missing link.
Old Jul 24, 2003 | 07:32 AM
dabrown's Avatar
Default Re: (devonic)
I would recommend the Hondata, I think you are in the same state as
boosted hybrid who tunes Hondata. I personally would go that route if you want to boost 8psi. I am waiting for my Hondata to come in to have it tuned on my wife's 98 Civic SOHC with the Apex Kit looking for 9psi with 440's.
Old Jul 24, 2003 | 07:50 AM
devonic's Avatar
but with hondata will i need other stuff? injectors etc..? or just plug and play
Old Jul 24, 2003 | 08:28 AM
turbod16y8's Avatar
smc and 450cc injectors and youre set.
Old Jul 24, 2003 | 08:48 AM
FredoSP's Avatar
hondata
Old Jul 24, 2003 | 11:40 AM
dabrown's Avatar
I was advised by a Hondata tuner that for the setup I am using to get 440's. The fuel pump was not needed. It's definetly not plug and play but like I was saying earlier, in your area you have a good tuner...
Old Jul 24, 2003 | 12:02 PM
hot90honda's Avatar
need 2 ask can i use the blue box on a 91 civic 1.6 sohc if so how ??????? NEED 2 KNOW ASAP
Old Jul 24, 2003 | 12:41 PM
devonic's Avatar
who's the tuner in my area?
whats the best way to go but still not expensive?
Old Jul 24, 2003 | 02:58 PM
GruvyTune's Avatar
New User
hondata for sure.
i've done several blue box to blue box (hondata) conversions all with great success!
Old Jul 25, 2003 | 02:20 AM
dabrown's Avatar
Default Re: Bye Bye Blue Box, But What's an Alternative? (GruvyTune)
I am not sure how far he is from your exact location. But I think it should be Boosted Hybrid That's his screen name
Old Jul 25, 2003 | 03:48 AM
EE_Chris's Avatar
Can Hondata control an automatic tranny?
devonic has an auto...so unless it can, Hondata isn't a real possibility.
Old Jul 25, 2003 | 04:01 AM
ekb18c's Avatar
Default Re: Bye Bye Blue Box, But What's an Alternative? (EE_Chris)
go with aem then.
Old Jul 25, 2003 | 04:18 AM
devonic's Avatar
aem...ugh i dont got that kind of money, im a working man, not a rich man
Old Jul 25, 2003 | 04:41 AM
Happyman's Avatar
So run VAFC Hack for a while til you can afford. That's what I'm doing. All you need for VAFC Hack is:
1.VAFC
2. 450CC injectors
3. 4 10ohm resistors(or resistor pack from crx)
4. Walbro 255 Fuel pump.
Old Jul 25, 2003 | 08:21 AM
dabrown's Avatar
Default Re: (Happyman)
The hack is perferct for a fix if you already have all the gear, if not then you might as well go for the Hondata. By the way Import Parts has a good deal on the Injectors right now for HT members. Oops forgot he has an Auto..... Well there's the Hack and EMS>
Modified by dabrown at 5:37 PM 7/25/2003
lDanny
Mar 30, 2005 02:14 PM
5thgencivic
Jul 8, 2003 02:53 PM
Sprockets
Nov 20, 2002 10:47 PM
Boostless97Lude
Sep 4, 2002 07:45 PM
