high idle and surging throttle
Old Jul 23, 2003 | 07:49 PM
jdm_rex's Avatar
Default high idle and surging throttle
Ive got a 91 crx si with a b16 and lately ive had high idle and it surges. It usually goes from 700 to 2400 and drops back down again. It used to only do it when it was cold but now it does it all the time. I think i might have a bad TPS because when im driving and i let off i can hear the motor stop accelerating and a couple seconds later i can here the actual throttle let off so it kinda jerks the car. Its a real pain in the *** when im trying to maintain a certain speed. Its throwing a code, im not sure which one because the last time i checked it was when i first did the swap and it was 02 censor that i never fixed so i assumed it was the same code. ill check it tomorrow and post it if its not just the 02. Any ideas please let me know asap. thanks in advance.
Old Jul 23, 2003 | 08:53 PM
allmotorsircrx's Avatar
turn the idle screw down on the t/b (was my problem) check all your vacume lines are correct, and make sure your TPS is getting the right voltage. that's all that's to it.
Old Jul 23, 2003 | 09:17 PM
blacksheep's Avatar
Default Re: high idle and surging throttle (jdm_rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_rex &raquo;</TD></TR><TR><TD CLASS="quote">Its throwing a code, im not sure which one because the last time i checked it was when i first did the swap and it was 02 censor that i never fixed so i assumed it was the same code.</TD></TR></TABLE>
check the code again.. then tell us what u come up with. Then maybe we can help.
Old Jul 24, 2003 | 12:39 PM
jdm_rex's Avatar
i checked the codes...i got 7-TPS, 17-VSS(i dont have my speedometer hooked up), 23-Knock sensor, 21-Vtec Solenoid(im running fields sfc with no input to ecu), and 2-oxygen sensor b
Old Jul 24, 2003 | 01:20 PM
FLATBLKCIVHB's Avatar
i think you should really have somebody at a shop look at your car with proper tools... like a volt ohm meter so stop by here and well figure it out.... now the only geustion is where do we get a tps sencor........
Later justin
Old Jul 24, 2003 | 06:44 PM
jdm_rex's Avatar
Default Re: high idle and surging throttle (FLATBLKCIVHB)
changed the TPS and good news, it doesnt surge like it did, bad news, it idles at 1700 constant. The idle is all the way down and i adjusted the screw with no success. I started playing with hoses and they all seem to be doing their jobs. I'm also still getting the TPS code which is strange because im actually making progress.
Old Jul 24, 2003 | 06:48 PM
blah13's Avatar
Adjust your throttle cable, turn the revs up to about 2000 with the screw before you do so you'll have some adjustibility when you try and bring it down with the throttle cable.
Old Jul 25, 2003 | 01:36 PM
Default Re: high idle and surging throttle (blah13)
yo justin i think u needa do a vac. test.... i think mike has a tester....
i.
49
Feb 17, 2014 12:53 PM
got00rice
Dec 30, 2009 12:16 PM
92ehatch
Nov 13, 2006 02:33 PM
Problemo
Jan 29, 2006 04:16 PM
TheHatchHog
May 15, 2003 10:01 PM
