ctr pistons on a gsr?will it work
Old Jul 23, 2003 | 06:52 PM
civic1320's Avatar
Default ctr pistons on a gsr?will it work
i have a 93 gsr and i baught ctr pistons.my qustion is will they fit,or will they hit the head.some say yes some say no.any help would be appreciated.
Old Jul 23, 2003 | 10:51 PM
Kataku2K3's Avatar
Default Re: ctr pistons on a gsr?will it work (civic1320)
They'll drop into your bottom end just fine and this is a very common build... As for the piston to valve clearance, that all depends on the cams... There would be no reason to run some insanely big cams with high lift and lots of duration since your compression isn't that high... Something along the lines of CTR/ITR cams would be a better option for power and for piston-valve clearance... Without any milling of the block/head you should be fine at 0,0... If you are worried about cam advance/retard then clay the motor... Good Luck
Old Jul 24, 2003 | 12:34 AM
OnebadJdmEg6's Avatar
From: being tracked by FAGS Docking PERCENTAGES, GAYFUKS
Default Re: ctr pistons on a gsr?will it work (Kataku2K3)
yes they will fit and work but i suggest not to use the gsr head because it will ping or detonate due to cumbustion chamber and valve clearance from the head to the ctr piston might be dangerous
Old Jul 24, 2003 | 05:49 AM
b19coupe's Avatar
Pistons will work, and not hit the head. Your compression will not be extremely high because the 93 GSR uses a B16 head, not the later model P72 head with the smaller combustion chambers.
Old Jul 24, 2003 | 06:25 AM
POWERLINE125nosLSVTEC's Avatar
Default Re: ctr pistons on a gsr?will it work (b19coupe)
youre lookin at 11.3:1 compression good luck!
Old Jul 24, 2003 | 07:39 AM
xJ.SLOTHx's Avatar
you'll be fine...its only OEM parts, not some insane full race spec. monster piston. just clay and check the clearances and you'll be straight.
Old Jul 24, 2003 | 08:05 PM
PHiZ's Avatar
the 93 GSr is the B17a, correct, I think the thread author should have clarified this, cause it may not be widely known.
-PHiZ
Also, the b17a is just a factory stroked B16 block, correct folks?
Old Jul 24, 2003 | 11:33 PM
acydphryck's Avatar
Default Re: ctr pistons on a gsr?will it work (PIMPASSBEOTCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPASSBEOTCH &raquo;</TD></TR><TR><TD CLASS="quote">ive got ctr pistons in a b18c1 in my hatch .you will have to play with the timing to keep it from pinging.i got a walbro fuel pump and have had very little problems...it hauls *** too. </TD></TR></TABLE>
i have a 'similar' setup on my hatch... will be tuning it with hondata s100 within a week or so. i set it up for road racing...
shandonwall
18
May 29, 2009 05:35 AM
Ra GS-R
Aug 1, 2007 04:56 PM
Driven
14
Apr 4, 2004 10:58 PM
McFly
Mar 2, 2003 08:01 PM
stretracr
Jun 26, 2001 06:16 PM
