Buying a 2G teg.....what to watch out for?
Old Jul 23, 2003 | 05:58 PM
I Want An Si's Avatar
Default Buying a 2G teg.....what to watch out for?
Looking at getting a 4door 2g Teg....manual...gs or ls.... what should i look out for when buying one?
Old Jul 23, 2003 | 06:04 PM
skunkintegra's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (I Want An Si)
take it straight to the car wash and get it really wet....
then get inside, and turn on your heater...
make sure there is no water getting in the cabin, on the passenger side footwell!!
big PITA!!
otherwise, look for the usual rust, and inspect the engine, you dont want an oily mess anywhere!!
i've also had to replace the radiator, and o2 sensor, and my MFR is on its way out...but this is on a 90...so i highly suggest finding a 93!!
Modified by skunkintegra at 9:13 AM 7/24/2003
Old Jul 23, 2003 | 06:20 PM
tegrakid's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (skunkintegra)
the only problem you might have is leakage, DA owner here where i live has a swamp in there trunk but i drilled a hole so it will drain to fix that, otherwise you will be hooked i love my G2 2 door LS my next is a rhd 4 door
Old Jul 23, 2003 | 06:57 PM
03 civic si hb's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (tegrakid)
when i had my 93 gsr i had the trunk problem and the water vent problem up front. they were caused by clogged drains, but they were a easy fix.
Old Jul 23, 2003 | 07:01 PM
DA-MAX's Avatar
main fuel relay(hard starts when hot) and blower motor resistor. those were the only common problems so far on mine and several others I've seen...both are easy DIY fixes though! other than that I love my G2 great car!
Old Jul 23, 2003 | 07:11 PM
mr.beeks's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (DA-MAX)
maintanance records
water leak in the trunk and pass side
faulty ignition control module and coil.
typical rear cam seal leak.
squeaky shocks and hatch plastic cover.
gs climate control.
screching brakes no mater what you do
ripped drivers seats
leaky headlights
other than that its a real nice car to own..
Old Jul 23, 2003 | 07:24 PM
Bill Hook's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (francisco flores)
I owned one and my probs were:
worn out drivers seat
cam seal leak
broken power antenna (easy fix)
beginnings of rust behind one of the rear fenderwells (early 90s Accords do this too)
My brakes always were cracking front rotors, but I suppose that was b/c I didn't know about good pads and how to take care of them - same are used on G3 'tegs.
Check out Consumer Reports or other used car buying guides, as they list documented trouble areas. Not many though.
Old Jul 23, 2003 | 07:54 PM
tegs4ever's Avatar
2g teg are the best man, i loved mine untell the day she was in a wreck, now i'm gonna try a 94 teg, but i didn't have really any probs with mine, except the leakage on the passenger side, but i could have fixed it but hadn't yet.....i say go for it if you find a nice one
Old Jul 23, 2003 | 08:15 PM
MrJasey's Avatar
main things are the usual
check timing belt and clutch, and basically anything like oil leaks and such. the water problems are minor and easy fixes.
Old Jul 23, 2003 | 08:50 PM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">main fuel relay(hard starts when hot) and blower motor resistor. those were the only common problems so far on mine and several others I've seen...both are easy DIY fixes though! other than that I love my G2 great car!</TD></TR></TABLE>
You hit that right on the button, I had to replace both of them. Both fairly easy to fix too. Check for rust in front of quarter panels, behind weatherstripping around door, and under the hatch.
Old Jul 23, 2003 | 09:10 PM
Bill Hook's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (Honda Hick)
Radiator is another prob, since Honda went w/ a metal core and plastic tanks, which vibrates apart after a while. You can find a good all-metal radiator for $200 or so, though.
Old Jul 23, 2003 | 09:26 PM
Rah Rah's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (Bill Hook)
Just bought a radiator for my DA from radiatorbarn.com. It has metal endtanks and it was only like 90-something bucks with a lifetime warranty .
Old Jul 23, 2003 | 09:28 PM
Rah Rah's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (Rah Rah)
Also, I just started getting water in through the passenger side. The water is coming from behind the dash. It drips right at your feet. I thought it was the weather stripping on the front windshield. It's peeling back...How did u guys fix it?
Old Jul 23, 2003 | 09:54 PM
Loveless's Avatar
watch for *** stain on the passenger side seat
Old Jul 24, 2003 | 05:02 AM
arw321's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (Loveless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">watch for *** stain on the passenger side seat</TD></TR></TABLE>
Old Jul 24, 2003 | 05:51 AM
IntEGNYC's Avatar
Default Re: Buying a 2G teg.....what to watch out for? (arw321)
rust, vibration, odd creakes, noises, etc...
bear in mind youre possibly looking at a 10+ year old car.
Old Jul 24, 2003 | 06:05 AM
MikeTV
Guest
Posts: n/a
lol....that was funny...
Anyway, I had a 92, and my distributor pack went shortly after I bought it. That will be something that you will probably have to replace soon
Old Jul 24, 2003 | 07:32 AM
wow didnt realize Tegs Leaked so much more than EFs! hehe
Im finding that most 4 Doors are Automatic and the ones that arent automatic are RED!
Yuck Phoey!
Looking at getting Black,Silver,White....would consider other colors too...just no RED, no RS's, and no automatics!
As far as the engine goes.....im looking at dropping in a b20 anyways so im not really concerned about the engine.....Ive worked on plenty of Honda engines so I know all their faults.....(i.e. Distributor)
Im lookin for more model specific information......
thanks
92EGMINIME
Apr 8, 2009 12:34 AM
TigerLy
May 1, 2008 09:55 AM
TigerLy
Apr 11, 2008 09:30 AM
ricerEJ8
Jan 10, 2008 03:15 AM
synester302
Apr 7, 2002 06:50 PM
