integra LS 93 rear sway bar on 4th gen civic SI
Old Jul 23, 2003 | 05:55 PM
Garrett's Avatar
Default integra LS 93 rear sway bar on 4th gen civic SI
Is it bolt on?
Old Jul 23, 2003 | 06:16 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: integra LS 93 rear sway bar on 4th gen civic SI (Garrett)
SEARCH
no you need to change the lower control arms as well or rig it
Old Jul 23, 2003 | 06:53 PM
zCivic's Avatar
Default Re: integra LS 93 rear sway bar on 4th gen civic SI (ninjaMONKEY)
as long as its a SI will bolt on. Just use the SI mounting brackets. If its a DX, HF, STD will need the SI mounting brackets for the chassis and rear LCA for the end links. You can rig it for the LCA but I've always got the rear LCA's with the sway bar. But if you have a SI its not that much of an upgrade its only 1mm larger in dia.
CivicSiRacer
Jun 11, 2011 07:45 AM
HT Chaplain
Jan 6, 2006 11:20 AM
JDMhatchback20
Feb 6, 2005 06:47 PM
wronghand
May 4, 2002 08:42 PM
Jan in Omaha
14
Aug 23, 2001 05:34 PM
