fixing rust!
Old Jul 23, 2003 | 05:20 PM
Nader_D's Avatar
Default fixing rust!
hey, ive started to get rust along the front + rear fenders, like every other honda, how would i go about fixing this?
Old Jul 23, 2003 | 05:43 PM
visionsOFmadness's Avatar
Default Re: fixing rust! (Nader_D)
tac weld u have to use sheet metal or replce what hae rusted
Old Jul 23, 2003 | 05:46 PM
thid92's Avatar
can I haz?
it all depends how bad its rusted. if its only surface rust u could sand it down and bondo it. if its rusted thru u might wanna weld on sheet metal
Old Jul 23, 2003 | 05:51 PM
hardcorepreston's Avatar
yep replace it. that is the best way to get rid of rust.bondo dosnt work well to keep the rust from coming back(unless its just a little surface rust). my tip is to just buy new front fenders and go to a junk yard and cut out the piecs you need on the rear and take it to the body shop. the reason it rusts I think is because there is a little lip underneath the fender that holds water( I cut it out).but it you want a cheap fix bondo makes a fiberglass repair kid that you can patch over the hole after you take out the rust spot.it just depends on the quality of work you want I guess. good luck
Old Jul 23, 2003 | 06:43 PM
Nader_D's Avatar
Default Re: (hardcorepreston)
all it is, is the surface rust, i just want to stop it before it gets any farther. ive heard to, sand down area, primer, bondo, sand, paint over? or something in that area. dunno. thanks any more help?
Old Jul 23, 2003 | 06:55 PM
NonovUrbizniz's Avatar
Loved
Default Re: (Nader_D)
yeah you can get away with that for a while but even then it'll probobly keep rusting...
Rust is called "cancer" when it comes to cars for a reason... even if you beat it for now it's REAL likely that it will come back... I have bd on both my front fenders... I sanded and primered them before they really rusted at all and 1 year later it's coming through again (and I used a rust inhibiting paint too).
Fyi for those who don't want this to happen.... actually F it I'm gunna start a thread on it... if search doesn't turn anything up.
Old Jul 23, 2003 | 08:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nader_D &raquo;</TD></TR><TR><TD CLASS="quote">all it is, is the surface rust, i just want to stop it before it gets any farther. ive heard to, sand down area, primer, bondo, sand, paint over? or something in that area. dunno. thanks any more help?
basically if all it is is surface rust and you want to just take care of it.(it sounds a lot easier than it really is.)rust sux.
My friend had the similar problem and he went to MAACO(or however its spelt) and they took care of the body work and it came out good (we'll see how well the paint holds up tho)
Old Jul 23, 2003 | 08:43 PM
ICEDOWT's Avatar
it really can be bad if not taken care of properly
they have stuff that eats rust make sure to use that
grind out any rust to make sure its all out and make
sure to use a good sealer so no more moisture can get in
also make sure your area is well prepped before priming
and painting make sure they dont have standing water on the
inside of your fenders. but most likely if you live where
it snows it it from the salt they they use on the roads that
inhibits this
4g4dcruisin
Paint and Body
Aug 6, 2010 08:57 PM
dumpedhard
Mar 16, 2009 04:22 PM
taking-back-sunday07
Apr 7, 2007 06:40 AM
go2sleep
May 18, 2006 06:36 PM
civichatch08
Aug 11, 2005 11:13 AM
