CRX Swaybar on an Integra?
Guest
Posts: n/a
Using the 1988 Style LCA's. Mainly because I may buy some Type R struts to go with my Type R springs, but if I can also use the CRX swaybar to my advantage, i'd do that. The sway bar is also 1988 style. HTH
Guest
Posts: n/a
Thanks, thats exactly what I wanted to know. I have a damaged crx for parts so that's why I asked. I pulled the LCAs out so I was just wondering if the crx swaybar was bigger or more advantageous than a stock integra RS one.
Guest
Posts: n/a
Thanks for the help.
If I were to put the CRX LCA's on my Integra, would I lose the current teg swaybar? ie is it connected to the factory RS/LS LCA's?
And if the factory sway bar is not connected to the lca's that i'm swapping for the crx's, could I add both rear sway bars
trooper0641
Feb 9, 2005 03:46 AM
91hondacrx
Dec 6, 2003 09:39 PM
elmalouno
Dec 24, 2002 12:14 PM
