Beaks kit on CX
Old Jul 23, 2003 | 03:22 PM
921.5CXEG's Avatar
Default Beaks kit on CX
I need to know what all parts besides the beaks kit, ITR rear sway, and the endlinks do I need? I know i need all the bushings and stuff, but while looking for them online i see that there are brackets that looks like the bar bolts to, their part number is 52317-SR3-010. Im not sure if i need these or not, since i think the beaks kit would eliminate this part, but i want to be sure first.
Old Jul 23, 2003 | 03:27 PM
b18c5go's Avatar
Default Re: Beaks kit on CX (921.5CXEG)
Funny you should ask. I just asked Wil at beaks the same question. Keep in mind I have a rear disc conversion from a 93 integra so some parts may not apply.
Here is his response:
Your '92 Civic CX would require the following, which I stock:
EG/DC Quick-Swap kit--$175
Integra endlinks with fasteners--$45/pr.
Did you swap out the LCA's when you did the rear disc conversion? I do not think that is necessary, but if you now have LCA's that can accept swaybar endlinks, you will have less to purchase. Otherwise, get yourself a set of LCA's from a '94-'01 Integra from a used parts yard, as the '93 is a different chassis (EF/DA vs. EG/DC).
Let me know if you have other questions or wish to place an order. Thanks for the inquiry!
-Wil
http://www.BeaksProducts.com
Old Jul 23, 2003 | 03:39 PM
921.5CXEG's Avatar
Default Re: Beaks kit on CX (b18c5go)
Cool, thats exactly what i wanted to know
SpeedDemonAaron
Oct 10, 2005 10:32 AM
BANNED_ID
28
Jul 11, 2005 09:33 PM
98EJ
Suspension & Brakes
Apr 6, 2005 06:20 PM
Kalokohan
12
May 31, 2004 03:37 PM
wdskuk
Aug 21, 2003 10:35 PM
