ITR front swaybar on 93 hatch cx??
Old 10-21-2003, 12:36 PM
New User
Kalokohan's Avatar
Default ITR front swaybar on 93 hatch cx??
I just got my hands on an ITR front swaybar (no endlinks) and I was wondering what kinds of hardware I'll need to install this on my 93 cx hatch which was not factory equipped with any swaybars.
BTW: I am also installing the matching ITR rear swaybar with beaks kit and gsr lca's. I tried searching but the only topics covered were the rear sways. Thanks!
Old 10-21-2003, 12:44 PM
.hugo's Avatar
Default Re: ITR front swaybar on 93 hatch cx?? (Kalokohan)
any front lca's that came with a front sway bar will do, the civic ex lca's will work or integra lca's.
Old 10-21-2003, 12:48 PM
owen_the_soyboy's Avatar
front lower control arms with swaybar endlink bolt holes.
endlinks and bolts.
D-brackets to mount the bar to the chassis.
and a mathcing ITR rear swaybar
Old 10-21-2003, 12:53 PM
New User
Kalokohan's Avatar
Default Re: ITR front swaybar on 93 hatch cx?? (owen_the_soyboy)
Cool, thanks guys! The matching ITR rear sway will go on first since I already have all the parts needed to make that happen. I appreciate all the help. What should I expect from this mod? Take into consideration that my car has never had any sways. Is this too excessive? Should I opt for smaller bars? I don't autocross now but I plan on getting into it in the future.
Old 10-21-2003, 01:09 PM
Former Moderator
B18C5-EH2's Avatar
I would not run such a big front bar on the car...
I'd try to run at most a 1992-1995 Si/Ex front bar and a pretty stiff spring in the rear or a bigger rear swaybar like a 22mm one.
Old 10-22-2003, 05:10 AM
New User
Kalokohan's Avatar
Default Re: ITR front swaybar on 93 hatch cx?? (B18C5-EH2)
I already am installing a 22mm ITR rear swaybar......I'm pretty sure USDM ITR's came with 22mm rear sways. So when all is said and done, I will have a 26mm front sway and a 22mm rear sway on my 93 cx hatch. For those who have had experience with this set-up, please share with me the pros and cons. Thanks.
Old 10-23-2003, 03:14 PM
rallycivic's Avatar
b18c5-eh2 - wouldn't that make the hatch crazy tail happy? i have only had my eh for a week so i don't have any personal experience driving an EH to the limits, but a friend had a bit of trouble keeping from spinning out in a bone stock 92 si and an ls powered cx hatch.
i want to have very slight understeer at the limit, what sway bar setup would be good for that?
TIA
~Steve
Old 10-23-2003, 03:31 PM
743power's Avatar
Default Re: ITR front swaybar on 93 hatch cx?? (rallycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rallycivic &raquo;</TD></TR><TR><TD CLASS="quote">b18c5-eh2 - wouldn't that make the hatch crazy tail happy? i have only had my eh for a week so i don't have any personal experience driving an EH to the limits, but a friend had a bit of trouble keeping from spinning out in a bone stock 92 si and an ls powered cx hatch.
TIA
~Steve</TD></TR></TABLE>
No, actually that setup should make the car pretty neutral, with predictable off throttle oversteer. I wouldn't put a 26 or 24mm (what size is the front itr bar?) on my car. At the most I would use the stock eg one like Tom suggested.
Old 10-23-2003, 10:56 PM
rallycivic's Avatar
Default Re: ITR front swaybar on 93 hatch cx?? (743)
thats good to know, thanks for the good info.
how bad is the understeer when using the front itr bar?
Old 10-23-2003, 11:15 PM
ill phil's Avatar
Yeah ITR front bar is 24mm. I'm running the 24mm GSR front with stock 14mm GSR rear and so far understeer isn't too bad and once a larger rear bar goes on, its should definitely feel better. Just MHO. Once I get the car on to a road course setting it should definitly give me a better idea towards the type of racing I'm trying to gear toward.
Old 05-31-2004, 07:38 AM
ScubaStevo80's Avatar
Default Re: ITR front swaybar on 93 hatch cx?? (ill phil)
Just want to confirm... to put any front swaybar on my EG (not factory swaybar equiped) I will need to get LCA's that were factory equiped with a swaybar. What options do I have? I'm looking to get a GSR/Si front swaybar.
Old 05-31-2004, 03:36 PM
Mike36's Avatar
Default Re: ITR front swaybar on 93 hatch cx?? (VolpeOwnsU)
gsr and type r front bar are the same size. 24mm. you will need the front lca's from any 94-00 integra or any from 92-95 civic lx or ex. the endlinks you will need to mount the bar are from a gsr 94-00. go to any import junkyard get them used or they will cost you a pretty penny brand new from the dealer. i have the current type r front and rear sway bars. the are great for the street but i guess if you are going to take your car to the track and want a slightly more neutral feel when taking hard turns then go with an ex/si front sway so there is less understeer. have fun with the install and be careful when you put the type r bar on w/o no front sway.
Old 05-31-2004, 03:37 PM
Mike36's Avatar
Default Re: ITR front swaybar on 93 hatch cx?? (egferio)
lol, what loser i am to replying to 5 month old topics. need to pay attention next. oh well
BANNED_ID
28
07-11-2005 09:33 PM
BumpinVTEC
01-14-2004 06:00 PM
maxxdout
04-01-2002 10:22 AM
YumYumRoLL
03-25-2002 07:49 AM
Quick Reply: ITR front swaybar on 93 hatch cx??
