Crunchy brake(?) Help..
Old Jul 23, 2003 | 01:21 PM
acuraLSSE95's Avatar
New User
Default Crunchy brake(?) Help..
Auto integra. Recently when I drive at normal speed 30-40mph and come to a stop, I hear a crunchy or interrupted Rubbing sound when I applied the brake pad, NO squeeks, just the sound I mentioned. Last time I changed my brake pad was a few years ago, keep in mind that my teg is Auto.
Can someone help out?
Old Jul 23, 2003 | 03:44 PM
EL Vap133's Avatar
Default Re: Crunchy brake(?) Help.. (acuraLSSE95)
Does your steering wheel shake at all? Kinda sounds like warped rotors...
Old Jul 23, 2003 | 03:55 PM
fivespeedintegra's Avatar
check your pads....they may be totally worn to the metal backing
Old Jul 24, 2003 | 11:43 AM
GuyInASpeedo's Avatar
More than likely you just need new brake pads.
Old Jul 24, 2003 | 05:54 PM
New User
Default Re: Crunchy brake(?) Help.. (Vap133)
well, It only happens when I drive at a normal speed. If I drive fast and apply brake, I really don't hear it. maybe it's that it's too noisy when I drive fast in traffic. Stopping isn't a problem, It will stop when I hit the brake, just the fact that it's making this wierd rubbing sound when I apply the brake slowly intermitenly in slow driving... rubbing against something.
any more comment?
thanks
Old Jul 25, 2003 | 04:15 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraLSSE95 &raquo;</TD></TR><TR><TD CLASS="quote">... any more comment?</TD></TR></TABLE>
Check your brake pads. That'll only take you a few minutes. Take off the wheels so you can check each inboard pad, too.
Old Jul 26, 2003 | 02:34 PM
New User
Default Re: Crunchy brake(?) Help.. (JimBlake)
I drove the car today. problem still happened but the steering wheel doesn't shake. as for taking off the wheel and check my front brake pads, What do I look for to know that I need to replace them? thanks
Old Jul 28, 2003 | 03:50 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraLSSE95 &raquo;</TD></TR><TR><TD CLASS="quote">... What do I look for to know that I need to replace them?</TD></TR></TABLE>
I don't have a good picture to post. Find a repair manual for your car (at the library?) & look up brakes. Maybe one of your friends works on his car & would show you...
The pads are the things that press against the rotor (disk). There's one inside & one outside at each wheel, and they are made of a steel plate with friction material. The friction material wears away, and when you have less than maybe 1 or 2mm thick you replace them.
c 2
Jan 29, 2008 07:06 PM
GeekinEK
Nov 2, 2006 09:40 AM
roundworldsobig
Aug 26, 2006 06:12 PM
jjaskula1
Dec 25, 2005 07:59 AM
blklude
Jun 27, 2003 06:30 AM
