Help! LS swap into 91 CRX DX!!! L@@K
I am putting a 1992 LS into my 1991 CRX DX.
I dont have a dizzy or harness. Which should I use?
(i do have the PR-4 ECU)
P.S The CRX had a D15 w/ points
TIA
TIA
Need to first covert the car to 4-injector wiring, and then use the CRX wiring harness on the Integra motor. Use 90-91 Integra distributor, injectors, ECU, and misc parts for your swap.
I get the points to injector conversion...
but i use the old harness with the new motor?
and i need to junk the obd1 ecu and get an obd0 out of a 90-91 along w/ the dizzy, and injectors? anything else?
p.s. thanks a bunch
p.s. thanks a bunch
I have a similar setup in my 91 CRX DX: 1996 B18B1 with 92 YS1 GSR tranny. I used the 90-91 OBD0 PR4 ECU, distributor and injectors. In addition to that you'll need to get some OBD0 injector clips and a resistor box. Reuse your DX harness and rewire it from DPFI to MPFI, rewire the coolant temp switch and extend a few sensor plugs and you'll be in good shape.
thanks guys, seriously a big help.
anyone have obd0 PR4 or dizzy or restitor box?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">rewire the coolant temp switch</TD></TR></TABLE>
could you elaborate on that please?
On the older OBD0 motors the coolant temp switch is on the back of the block to the left above the oil filter as a big rubber plug with 2 female connectors. On the 92 LS it's either mounted on the in the same location on the back of the block or on the thermostat housing but as a regular 2 prong plastic sensor. You will need to rewire the plug on your DX harness with a regular 2 prong sensor plug and extend it if necessary.
Check your B18A1 block to confirm this though. As for my 96 B18B1, I had to rewire it and extend the wires to the thermostat housing. I have a 90 B18A1 in my garage and it is still located above the oil filter but as a 2 prong regular sensor as I mentioned.
VTECVillain
Apr 28, 2002 12:34 AM
