Brake Pad Wear
My brake pads are getting to the point that they will need to be replaced soon, and I was thinking about going with the Axxis Ultimates, but I was wondering if anyone knew how the wear on these pads compares to the OEM pads. I have been pleased with the wear on the OEM pads and I was wondering if I should expect a shorten life from the Axxis pads. Thanks.
They aren't as good as OEM for wear, but they aren't bad. Going w/better rear pads can help improve the life of the fronts. The much better feel and increased capabilities were worth it to me in regard to Ultimates.
Ultimates don't squeak. However, using a good grease, shims and new rotors would be a good place to start for quiet brakes.
In fact, Ultimates have built-in shims, so you are double shimmed when using them.
Call Andie up at Cobalt Friction (www.cobaltfriction.com) tell him you are from Honda-Tech.com and he'll hook it up.
Mine are in dear need of replacement too. I went on a mt. run back in april and smoked the **** out them. There are hotspots on the rotors, but amazingly the StunnaZone rotors aren't warpped! The pads just fade like really fast now. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona »</TD></TR><TR><TD CLASS="quote">Go with OEM</TD></TR></TABLE>
OEM
Pretty cheap,semi-mettalic, You know they'll work.
Seems like a no-brainer to me.
OEMPretty cheap,semi-mettalic, You know they'll work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me »</TD></TR><TR><TD CLASS="quote">
OEM
Seems like a no-brainer to me.</TD></TR></TABLE>
Dont buy OEM till you give Andie a call. I'll never buy OEM again he hooks it up so hardcore.
http://www.cobaltfriction.com
My axxis ultimates are very quiet. havent squeaked yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR »</TD></TR><TR><TD CLASS="quote">can't go wrong with OEM and they're the only one's that i've used that don't squeak.....all the aftermarket one's that i've tried squeak and drive me CRAZY
OEM
OEM
OEM
Pretty cheap,semi-mettalic, You know they'll work. </TD></TR></TABLE>
Just not very well.
Ultimates should be the same or cheaper than OEM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me »</TD></TR><TR><TD CLASS="quote">Seems like a no-brainer to me.</TD></TR></TABLE>
You said it, not me.
OEMPretty cheap,semi-mettalic, You know they'll work. </TD></TR></TABLE>
Just not very well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bill Hook »</TD></TR><TR><TD CLASS="quote">
Just not very well.
To each his own.
Just curious as to the price, I just bought OEMs yesterday if the "ultimates" are much cheaper maybe you've convinced me.
Just not very well.
</TD></TR></TABLE>To each his own.
Should be able to get front and rear both for under $100.
Ultimates may be harder on rotors than OEM, but the rotor should last the life of the pad. I've had too many problems with using old rotors, so I buy new each time.
hondaracin24
Nov 19, 2004 02:48 PM
Propulsion
Apr 3, 2002 10:53 AM
