Stock B18C5 for Road Racing, is it Reliable?
Old Jul 23, 2003 | 07:24 AM
jwaked's Avatar
Default Stock B18C5 for Road Racing, is it Reliable?
I know this question might sound like it belongs in the Road Racing forum but I need to know from the owners. I blew up my race motor and need a motor ASAP to get back to the track. I was thinking of buying a Type R engine complete just to finish this season but need to know if it can handle the abuse in stock form. It will have fluidyne radiator and Fal Fan. Cooling is no problem.
Thanks
Jay
Old Jul 23, 2003 | 07:35 AM
Spoond TEG's Avatar
Default Re: Stock B18C5 for Road Racing, is it Reliable? (jwaked)
The B18c5 is a very capable engine and it will do fine. I am not sure what class you are running in but I think if you are running in a modified class then you will have to do some mods to it.
Old Jul 23, 2003 | 07:47 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">I know this question might sound like it belongs in the Road Racing forum but I need to know from the owners. I blew up my race motor and need a motor ASAP to get back to the track. I was thinking of buying a Type R engine complete just to finish this season but need to know if it can handle the abuse in stock form. It will have fluidyne radiator and Fal Fan. Cooling is no problem.
Thanks
Jay</TD></TR></TABLE>
Yes, it is capable and can handle a good amount of abuse as long as it is maintained well.
Chris - who notes that he said 'abuse in stock form', so mods don't apply.
Old Jul 23, 2003 | 08:21 AM
jwaked's Avatar
Default Re: Stock B18C5 for Road Racing, is it Reliable? (Chris N)
What I have in mind is running the motor completely stock internally, with bigger radiator, fans, and bolt ons. Maybe a ported intake. The transmission will have the ATS close gear ratio set. Do you think it can handle it? Running it at high RPMs for more than 30 minutes per race?
Thanks
Jay
Old Jul 23, 2003 | 08:24 AM
davidnyc's Avatar
I would add an oil cooler, baffled oil pan, appropriate gauges to monitor the situation and it should be fine...at least this is what I am doing for the build-up of my road race ITR.
Old Jul 23, 2003 | 08:40 AM
jwaked's Avatar
Default Re: Stock B18C5 for Road Racing, is it Reliable? (davidnyc)
Have gauges and oil cooler. Where can I find a baffled oil pan? Is it a stock replacement?
Jay
Old Jul 23, 2003 | 08:43 AM
spoon_ek9's Avatar
dead reliable. just make sure your cooling and oiling system are working fine.
edit, for the oil pan, this is what we did.
Old Jul 23, 2003 | 09:52 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">I would add an oil cooler, baffled oil pan, appropriate gauges to monitor the situation and it should be fine...at least this is what I am doing for the build-up of my road race ITR.</TD></TR></TABLE>
All very good ideas.
Old Jul 23, 2003 | 10:41 AM
b18c_dc2_type_r's Avatar
Sure since you are in the right forum, go for all motor B18C with right compression and some basic mods....
Old Jul 23, 2003 | 04:58 PM
Cal's Avatar
Cal
Default Re: Stock B18C5 for Road Racing, is it Reliable? (b18c_dc2_type_r)
If you want to be fast on a raod course learn to drive the car with teh engine stock.
You will be faster by investing money in HPDE's, tires, and brake/suspension upgrades, than you will by adding 20hp and 15tq.
A stock B18C5 with a "good" header (SMS) or not, and a clean air filter will be more than fast enough for anyone who isn't at an elite level, and doesn't have to make 200whp to hang with the pack.
Once you are being outdriven and overpowered than it is time to upgrade.... For most people that is hardly ever....
Things that win races, or drive consistant laps.
Driver
Brakes
Tires
Suspension
Power
Old Jul 23, 2003 | 05:08 PM
BimmerSteven's Avatar
Default Re: Stock B18C5 for Road Racing, is it Reliable? (Cal)
It sounds like jwaked is already familiar with racing - with two road-race specific vehicles in his "sig" and a couple karts as well.
Stock B18C5 + baffled pan = strong reliable power
Old Jul 23, 2003 | 07:59 PM
GettaluvR's Avatar
New User
Default Re: Stock B18C5 for Road Racing, is it Reliable? (BimmerSteven)
stock will be fine unless u drive like a moron IE miss shift ...etc
Old Jul 23, 2003 | 08:29 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cal &raquo;</TD></TR><TR><TD CLASS="quote">If you want to be fast on a raod course learn to drive the car with teh engine stock.
Driver
Brakes
Tires
Suspension
Power</TD></TR></TABLE>
I think he just wants to know about the reliability of the engine as a replacement to his engine for the remainder of the race season.
Old Jul 23, 2003 | 11:12 PM
SBR*EG4's Avatar
The b18c5 is at home on the track...a baffled oil pan is definetely good money spent, as well as gauges to monitor her while you rape her through the corners.
Old Jul 24, 2003 | 05:42 AM
jwaked's Avatar
Default Re: Stock B18C5 for Road Racing, is it Reliable? (SBR*EG4)
BimmerSteven and Chris N are right. I need to know if it can handle the rest of the season. I got the rest, just need and engine now that has some power and could handle the abuse.
Thanks
Jay
Old Jul 24, 2003 | 06:45 AM
Spoond TEG's Avatar
Well the short answer is YES absolutely. Stock B18c5 is a real contender.
Old Jul 24, 2003 | 07:34 AM
chad's Avatar
Moderator
Default Re: Stock B18C5 for Road Racing, is it Reliable? (Spoond TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoond TEG &raquo;</TD></TR><TR><TD CLASS="quote">Well the short answer is YES absolutely. Stock B18c5 is a real contender. </TD></TR></TABLE>
with toda goodness even better!!
Old Jul 24, 2003 | 08:09 AM
goern-R's Avatar
Default Re: Stock B18C5 for Road Racing, is it Reliable? (chad)
I, along with a few other ITR guys here in AZ, have done numerous HPDE's in the dead of summer, when it was 110 degrees outside. I have just bolt ons and no additions to the cooling systems and have never had any overheating problems at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
...and my header is a Toda so that could explain everything I don't know where you live, but if it can survive a hot AZ day in June, it can handle just about anything.
I would doubtlessly trust a stock ITR engine to help you finish out your season.
my .02.
Old Jul 24, 2003 | 08:31 AM
Chris N's Avatar
I would make sure to do the things david mentioned above. Especially the baffled oil pan. No one likes having vtec not engage until 7000+ rpm while turning or tracking out.
But YES, the B18C5 can handle the load for your race series.
Chris - who thinks read comprehension is bad in this thread.
Old Jul 24, 2003 | 08:40 AM
Ex-ITR5874's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwaked &raquo;</TD></TR><TR><TD CLASS="quote">Stock B18C5 for Road Racing, is it Reliable?
Yes !
40k km pure race application here... only oil change and cleaning that bitch sometimes..... Rev limit 9000, shorter gears.. No probs and good power.
crazes
Oct 10, 2014 09:26 PM
AcuraHondaJess
Oct 9, 2009 03:27 PM
vtecn8ive
13
Jul 15, 2005 04:46 AM
91hatchcivic
Feb 8, 2003 10:37 AM
fso_BamBam
Sep 28, 2001 07:14 AM
