Just blew my stock engine have some questions.
Old Jul 23, 2003 | 07:23 AM
DjFreeze's Avatar
Default Just blew my stock engine have some questions.
ok heres the deal yesterday i was driving and i mean the rain came down! well to make a long story short, my aem intake sucked in alot of water and broke a rod.. im not to upset since it was only a DX engine. Well my question is can i pull the DX engine alone out (leaving the tranny etc. in) and can i drop an EX engine in its place. Would i only need to buy a EX ecu or what? any help would be great. thanks!
Old Jul 23, 2003 | 07:34 AM
1dumbscreenname's Avatar
Default Re: Just blew my stock engine have some questions. (DjFreeze)
it would be easier to just remove the whole setup and drop in the ex motor tranny and ecu. the ex gearing is better than our dx tranny gears. it isnt that expensive to begin with so do the whole swap.
Old Jul 23, 2003 | 07:35 AM
ki3t's Avatar
This user can set his title.
It would be easier to swap the whole DX motor out and replace it with an ex motor. What you would need is to do is get an EX ECU and wire a vtec line in so that your vtec my engage. Other than that I think that's all you need. Maybe some other wiring issues but I'm not sure.
Since I am assuming your car is an DX you don't have to worry about ABS axels and that crap. Engine mounts should be the same.
Correct me if I am wrong someone.
Old Jul 23, 2003 | 07:41 AM
DjFreeze's Avatar
Default Re: Just blew my stock engine have some questions. (B18cR-Ej1)
so what kind of wiring would i have to do?
Old Jul 23, 2003 | 07:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18cR-Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">It would be easier to swap the whole DX motor out and replace it with an ex motor. What you would need is to do is get an EX ECU and wire a vtec line in so that your vtec my engage. </TD></TR></TABLE>
the ex ecu should take care of the V Tec wiring
Old Jul 23, 2003 | 07:54 AM
RSZero1's Avatar
Default Re: Just blew my stock engine have some questions. (1dumbassscreenname)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1dumbassscreenname &raquo;</TD></TR><TR><TD CLASS="quote">
the ex ecu should take care of the V Tec wiring</TD></TR></TABLE>
No the EX ECU will not take care of the vtec wiring, you still need to run wiring since the dx engine harness does not have it, dx eng is not vtec...
Old Jul 23, 2003 | 07:58 AM
Default Re: Just blew my stock engine have some questions. (RSZero1)
ok, i figured that the swap would also use the ex wiring harness. my bad.
Old Jul 23, 2003 | 07:43 PM
DjFreeze's Avatar
so wait what do i have to do, i gotta do this asap. i appreciate all the help sofar!
Old Jul 23, 2003 | 07:52 PM
ace1875's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjFreeze &raquo;</TD></TR><TR><TD CLASS="quote">so wait what do i have to do, i gotta do this asap. i appreciate all the help sofar! </TD></TR></TABLE>
get you the z6 motor bolt it on get the ECU put it in if you can afford the EX harness buy it inside and out. if you can't run the VTEC wires.
Old Jul 24, 2003 | 03:28 AM
devonic's Avatar
you'll also have to run a wire for a knock sensor too, DX don't have them.
i just blew 2 pistons in my dx motor too, but i already have it all wired up for the ex motor/tranny im getting since i had a mini me swap in it.
Old Jul 24, 2003 | 06:14 AM
DjFreeze's Avatar
Default Re: (devonic)
so basicly just that wire, also could you take pics of what your wiring looks like to run the vtec. other than that it should run perfect?
Old Jul 24, 2003 | 06:17 AM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSZero1 &raquo;</TD></TR><TR><TD CLASS="quote">
No the EX ECU will not take care of the vtec wiring, you still need to run wiring since the dx engine harness does not have it, dx eng is not vtec...</TD></TR></TABLE>
Depends on the year. I think I remember one of the years all the models came wired for VTEC from the factory even if they didn't have VTEC.
Old Jul 24, 2003 | 06:31 AM
devonic's Avatar
i just ran 2 additional wires into my ecu harness, one for knock sensor and one for vtec
Old Jul 24, 2003 | 06:45 AM
ki3t's Avatar
Forgot about the knock sensor but that should be the only two wires you have to run. Good luck.
Old Jul 24, 2003 | 08:32 AM
DjFreeze's Avatar
Default Re: (B18cR-Ej1)
ok thanks alot guys i really appreciate all this help. hopefully i get it done this sat.
Old Jul 24, 2003 | 08:58 AM
LoNslo's Avatar
Default Re: (DjFreeze)
did u ever get a cost on how much the EX engine/tranny/ecu is going to run ya?
Old Jul 24, 2003 | 01:27 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjFreeze &raquo;</TD></TR><TR><TD CLASS="quote">ok heres the deal yesterday i was driving and i mean the rain came down! well to make a long story short, my aem intake sucked in alot of water and broke a rod.. im not to upset since it was only a DX engine. Well my question is can i pull the DX engine alone out (leaving the tranny etc. in) and can i drop an EX engine in its place. Would i only need to buy a EX ecu or what? any help would be great. thanks!</TD></TR></TABLE>
the easiest way to do it would be to get a complete ex swap, complete with the wiring harness. if your car is a 96-98, make sure the engine and wiring harness is a 96-98, if its a 99-00 then get a 99-00 engine. if you get the correct year the engine harness will just plug in. make sure to get the ecu too.
Old Jul 24, 2003 | 02:15 PM
owen_the_soyboy's Avatar
Default Re: Just blew my stock engine have some questions. (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">
Depends on the year. I think I remember one of the years all the models came wired for VTEC from the factory even if they didn't have VTEC.</TD></TR></TABLE> true all 1992 are prewired for vtec.
Old Jul 24, 2003 | 02:22 PM
PhatHardy's Avatar
Default Re: Just blew my stock engine have some questions. (owen_the_soyboy)
92-95 sohc vtec's didn't have knock sensor's so you don't have to worry about that, and you won't have to do any wiring at all as long as you get a 92-95 civic ex engine wiring harness just plug that in and plug the p28 ecu(92-95ex ecu) and you'll be set. It's easy as pie.
Old Jul 24, 2003 | 06:20 PM
dragonhaven2001's Avatar
Default Re: Just blew my stock engine have some questions. (PhatHardy)
Yep, 1992 were all wired for vtec
Old Jul 24, 2003 | 10:44 PM
PhatHardy's Avatar
Default Re: Just blew my stock engine have some questions. (dragonhaven2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonhaven2001 &raquo;</TD></TR><TR><TD CLASS="quote">Yep, 1992 were all wired for vtec </TD></TR></TABLE>
What the hell do you guys mean when you say they are wired for vtec, do you even know what you are guys are talking about, or did you hear this off some other dude. Just clear up what the hell you guys are talking about.
Old Jul 24, 2003 | 11:29 PM
eh2 nihonjin's Avatar
pull out the whole thing it's easier besides you might as well change clutch flywheel release bearing etc etc while you have the engine out and if you got the cash 4.9 final drive and quaife LSD
Old Jul 24, 2003 | 11:50 PM
elwood's Avatar
Default Re: Just blew my stock engine have some questions. (eh2 nihonjin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh2 nihonjin &raquo;</TD></TR><TR><TD CLASS="quote">if you got the cash 4.9 final drive and quaife LSD </TD></TR></TABLE>
mmmmm.........d series lsd!
Herbie
Nov 18, 2014 09:57 AM
SpecialKej
Dec 6, 2005 06:53 PM
1996civicDX
Apr 8, 2003 06:56 AM
turbod16y7vtec
Sep 27, 2002 08:09 PM
