C&R Racing radiator
Old Jul 23, 2003 | 07:02 AM
Project X's Avatar
Default C&R Racing radiator
Anyone know the thickness of the C&R Racing radiator?
Also, how many layer is it?
Also, full specs like the cooling capacity, cooling efficient, etc, if possible.
Old Jul 23, 2003 | 07:10 AM
RTW DC2R's Avatar
Default Re: C&R Racing radiator (Project X)
how bout contacting C&R directly? or maybe on the website?
Old Jul 23, 2003 | 07:43 AM
Warren's Avatar
Wrong-Way Wang
You'll have less install problems with a Fluidyne. Namely missing or incorrectly sized fittings.
Warren
Old Jul 23, 2003 | 08:05 AM
sgT's Avatar
sgT
Default Re: C&R Racing radiator (Warren)
C&R = low quality
Old Jul 23, 2003 | 08:37 AM
migs's Avatar
Default Re: C&R Racing radiator (sgT)
What fittings are you talking about? (mine fit in just fine)
Old Jul 23, 2003 | 09:48 AM
Project X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">C&R = low quality</TD></TR></TABLE>
What do you mean? Can you elaborate on that?
I would think the C&R rad is decent considering the Realtime
Racing RSX is using it.
http://www.realtimerl.com/cars/cars.htm
Old Jul 23, 2003 | 12:24 PM
Footwork's Avatar
http://www.crracing.com/products/
Old Jul 23, 2003 | 01:09 PM
Pho Real's Avatar
Default Re: C&R Racing radiator (Primo.)
I think they come with a Slim Fan already. Also when I called them they said they make them for Nascars, not sure if that is true or not.
Old Jul 23, 2003 | 05:07 PM
Phoenix_ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">
touring cars also destroy their radiators often. at least ours did.
Old Jul 24, 2003 | 10:35 AM
sgT's Avatar
sgT
Default Re: C&R Racing radiator (delinquent)
the overflow port is not sealed and leaks
the overflow port is smaller than stock hence requires you to adapt the size to the stock overflow bottle
the fans are mounted on large brackets which take up way too much space
Im sure realtime probably does a lot of extra welding to the radiators they use
I would get a fluidyne over a C&R anyday.
Old Jul 24, 2003 | 11:06 AM
Project X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">the overflow port is smaller than stock hence requires you to adapt the size to the stock overflow bottle</TD></TR></TABLE>
I'm not quite understand this part. Can you explain this part?
Old Jul 24, 2003 | 11:56 AM
sgT's Avatar
sgT
the nipple on the C&R is 1/4" the nipple on the overflow bottle is 3/8"
Old Jul 24, 2003 | 01:27 PM
skrewdlude's Avatar
hey,
I have the C&R in my turbo prelude. 0 problems with any of the things you stated. C&R is actually a performance core. Fluidyne just uses bigger cores, they are standard cores, just thicker. I would take the C&R over fluidyn anyday of the week.
Josh
Honda Gen
Performance
34
Oct 28, 2010 03:18 PM
Bserieskiller
Mar 15, 2009 12:32 AM
cpforyou
Jul 3, 2005 10:16 AM
Project X
Mar 9, 2005 11:45 AM
