Relocation of battery question
Old Jul 23, 2003 | 05:41 AM
tunes12's Avatar
Default Relocation of battery question
For all those who have relocated their battery to the trunk, did you use some sort of in-line fuse, just in case the wire that goes from the battery to the starter becomes frayed and contacts the chassis somewhere? If so, what amperage fuse do you use? Thanks in advance.
Old Jul 23, 2003 | 08:32 AM
Audipwr1's Avatar
Default Re: Relocation of battery question (tunes12)
yeah you should
use big gauge wire
i started with 8 gauge and it wasnt enough to energize the starter so i had to add another line in parralel to get it to turn over
Old Jul 23, 2003 | 08:35 AM
tunes12's Avatar
Default Re: Relocation of battery question (Audipwr1)
I am using a big guage wire, 4 guage I think, it's from an extra set of jumper cables I had lying around. That's not the problem, it turns right over. My question is was what amperage fuse should I use in case the wire wears through somewhere?
Old Jul 23, 2003 | 09:37 AM
Audipwr1's Avatar
welll draw on a starter is 130-175amps so plan above that
Old Jul 23, 2003 | 11:46 AM
tunes12's Avatar
I noticed the fuse in the fuse box under the hood for the battery is only 80 amps. Can you explain this? I was assuming that most people that have relocated their battery have added a fuse for safety. Maybe I'm wrong.
Old Jul 28, 2003 | 05:07 PM
Leo95SE's Avatar
i just finished my relocate this evening.
i used a 100 amp stereo type inline fuse. so far, so good..
also used 2 gauge wire for both power and ground.
notnic3
Jun 12, 2017 11:26 AM
vesperfx
Audio / Security / Video
Jun 27, 2008 07:34 AM
Emmanuel2112
Jun 24, 2008 06:10 AM
AntMan401
Feb 19, 2008 09:50 PM
crxpwr1
12
Mar 12, 2007 12:12 PM
