idle bounces from 800-1600
Old Jul 23, 2003 | 02:23 AM
Civic Racer X 7's Avatar
Default idle bounces from 800-1600
I've had this problem for 2 years now. Tried everything from checking for air in the coolant system to adjusting the timing and idle screw. just today I changed the EACV. It still bounces. Only does it when its warm and I can make it stop if I adjust the idle super low (500 rpm) lol in which case it will fluctuate around a lil then settle at 500. Its had a code 20 (ELD) for awhile now too but no ther codes any idea whats causing this? I hate a crappy idle!
Old Jul 23, 2003 | 03:55 AM
keithv's Avatar
Default Re: idle bounces from 800-1600 (Civic Racer X 7)
did you check for any vacuum leaks???
and just for *****, try adding some hondabond to the idle screw. supposedly that is a source of vacuum...
Old Jul 23, 2003 | 06:11 AM
Cam79's Avatar
Default Re: idle bounces from 800-1600 (keithv)
Mine has done that **** for awhile now too, F!@K it!
Im just going to put a new motor in, I have other issues with the car.
Old Jul 23, 2003 | 07:19 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
check TPS voltage...below .45v closed and it will make idle bounce. idle will also jump if the idle is set too high with idle screw. try reseting idle using procedure from helms.
dc4b20
22
Dec 3, 2012 09:54 PM
DC2*Integra
Sep 20, 2005 12:51 PM
Pele
Feb 9, 2003 01:01 AM
