installed jdm itr header and smsp cat but check engine light is on
Old Jul 23, 2003 | 01:44 AM
Seedc2's Avatar
Default installed jdm itr header and smsp cat but check engine light is on
The smsp cat has 2 bungs for the o2 sensor just like the stock cat. When I recived the smsp cat one of the bungs was covered with a bolt. So I installed one o2 sensor on the header and one on the cat. (hope thats right)
Then I turned the car on and got check engine.. then realized that the o2 sensor was not plugged in on the primary.. turned off the engine off and crawled underneath and plugged it in.. turned the engine on again.. still check engine light remains on.. just went for a test drive anyways.... OMG sweet
anyways should I give the check engine light to turn off itself? or reset my ecu now? ... what are my options..
Thanks to alan909, he helped me get this bitch on my car .. finished around 2am.. not to mention he has work today
Old Jul 23, 2003 | 02:25 AM
2kgs-R's Avatar
Default Re: installed jdm itr header and smsp cat but check engine light is on (kendogg)
you have to reset the ecu.
Old Jul 23, 2003 | 08:39 AM
Seedc2's Avatar
Default Re: installed jdm itr header and smsp cat but check engine light is on (2kgs-R)
whats the best way to reset the ecu? unplug the positive plug on the battery?
Old Jul 23, 2003 | 09:02 AM
Try2Live4Christ's Avatar
There's a fuse that you can unplug and plug back. You have to look in the fuse panel under the hood. I'm not exactly sure which fuse it is though....I know I had to do that so my check engine light would go off.
Old Jul 23, 2003 | 09:04 AM
Seedc2's Avatar
Default Re: installed jdm itr header and smsp cat but check engine light is on (Try2Live4Christ)
heh thanks.. i figured out which ones.. its the 15 and 7.5 located in the top left hand corner. lets try this and hopefully itll make my cel light go off brb
Old Jul 23, 2003 | 09:18 AM
Seedc2's Avatar
got it.. the second I started my car the cel went away! awesome!
and before the reset.. my car was idling very strange.. all fixed!!!!!!!!!!!!!!!!!
Old Jul 23, 2003 | 11:20 AM
00DVPGSR's Avatar
Default Re: (kendogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kendogg &raquo;</TD></TR><TR><TD CLASS="quote">got it.. the second I started my car the cel went away! awesome!
and before the reset.. my car was idling very strange.. all fixed!!!!!!!!!!!!!!!!!</TD></TR></TABLE>
Your ECU was in limp mode which is why you had a weird idle...you also probably could not got past 6K RPM either. Correct?
How much of a difference did the header make?
freddysEF
Feb 11, 2008 08:59 PM
almostboostedgsr
Mar 1, 2007 06:08 AM
silentdeath12886
Feb 13, 2007 11:43 AM
hlee5363
Dec 13, 2005 11:50 AM
dmckrazy45
Jun 1, 2005 07:23 AM
