where to buy NEW LS pistons
Old Jul 23, 2003 | 12:19 AM
wm5holla's Avatar
Default where to buy NEW LS pistons
ctr pistons go for 300 on jdm web site but where can i get new LS pistons or can u rebuild ur pistons by putting in new rings or what.. i want a lil better pistons what should i ?
Old Jul 23, 2003 | 12:22 AM
wm5holla's Avatar
Default Re: where to buy NEW LS pistons (wm5holla)
heres my issue i want to put in vtec pistons but i scared of VALVE CLEARNCE. so if i CANT put vtec pistons i was thinking about using my old pistons, would new rings help?
Old Jul 23, 2003 | 01:59 AM
eg_type_r93's Avatar
new rings will only help if you bore/ hone the cylinder walls because the rings will seat them selfs into the cylinder walls for the best seal
Old Jul 23, 2003 | 06:43 AM
Fkned2003's Avatar
call weisco and ask for Brian Nutter best salesman you will find, he'll get you what your looking for.
Old Jul 23, 2003 | 06:53 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: where to buy NEW LS pistons (Fkned2003)
Well what are your goals? What kinda compression are you looking for? What cams are you running/going to run? What mods are done now? What do you have for tuning?, etc.... Sure I could tell you to get CTR pistons or something along the lines of that but on a stock motor w/ an intake and no tuning capabilities it's going to be a waste of money.
Old Jul 23, 2003 | 05:30 PM
wm5holla's Avatar
Default Re: where to buy NEW LS pistons (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Well what are your goals? What kinda compression are you looking for? What cams are you running/going to run? What mods are done now? What do you have for tuning?, etc.... Sure I could tell you to get CTR pistons or something along the lines of that but on a stock motor w/ an intake and no tuning capabilities it's going to be a waste of money.</TD></TR></TABLE> well im not tryin to have super fast hatch, i just want some thing that moves around 14.5 14.7
Old Jul 23, 2003 | 06:23 PM
Mr Hammond's Avatar
a/k/a Jomo
So wait is this an LS motor in an LS hatch or a civic hatch. I mean hell you could get mid-high 14's in a civic hatch by just dropping the motor in. Is this an Integra LS?
Old Jul 24, 2003 | 08:12 AM
wm5holla's Avatar
civic hatch
Old Jul 24, 2003 | 08:16 AM
wm5holla's Avatar
Default Re: (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">new rings will only help if you bore/ hone the cylinder walls because the rings will seat them selfs into the cylinder walls for the best seal</TD></TR></TABLE> it will be honed
Old Jul 24, 2003 | 05:50 PM
JCushing's Avatar
Default Re: (wm5holla)
why would you have valve clearance issues with ctr pistons?
did you try acuraautomotiveparts.net
the more i think about your question the more questions i have... please elaborate more before i make fun of you
Old Jul 24, 2003 | 09:48 PM
10K2HVN's Avatar
Default Re: (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">the more i think about your question the more questions i have... please elaborate more before i make fun of you</TD></TR></TABLE>
haha..you mean guy!
yeah i agree, can you give us more info please...?
i figure you have a FULL LS (no VTEC ) from the links in you sig but you havent actually told us that you do have an LS motor..?
..but just off of speculation that you do..imma gonna give you some food for thought?
Now, ive heard that the LS head is like the PR3 head (hence PR4). But it has bigger chambers then any VTEC head (P72 or PR3). Since all B-Series Motors have the the same bore (except the B20)..the only way the PR4 can have bigger chambers is to have more clearance up top! which means more room for pistons and valves. Plus, the LS cams dont lift any higher then any VTEC lobes (stock)..and the VTEC valves are bigger then LS valves (33mm instead of 31mm) so there shouldnt be a problem there... so what do you think..?
Now about the pistons..if your piston is in good shape, then you can reuse them if you still wanna use your LS pistons. You'd have to hone the walls for the new rings but this would make your pistons to wall clearance bigger and thats not cool.. or i heard you can Dry Film Coat the pistons side skirts and this will take up some space for better piston to wall clearance. Or you buy new VTEC pistons and do the same procedure.. or buy Over bore OEM pistons and bore and hone to spec...your choice!
-10k
HTH, now can anyone try to help me out...?
https://honda-tech.com/zerothread?id=572809
Old Jul 25, 2003 | 12:13 AM
wm5holla's Avatar
Default Re: (10K2HVN)
what is a pr3 head?
Old Jul 25, 2003 | 12:19 AM
wm5holla's Avatar
i have a b18a short block! the only resaon i wanted to get new pistions or new rings so.. i could shave miles off my motor and it should last LONGER. what is the pistons to wall clearance being a lil bigger NOT cool? people on ht have told that ctr.itr have to high of adome to for a ls motor.. how i do find out the truth with out claying my motor?
Old Jul 25, 2003 | 12:22 AM
wm5holla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Well what are your goals? What kinda compression are you looking for? What cams are you running/going to run? What mods are done now? What do you have for tuning?, etc.... Sure I could tell you to get CTR pistons or something along the lines of that but on a stock motor w/ an intake and no tuning capabilities it's going to be a waste of money.</TD></TR></TABLE> i would like to rasie my C/R to at least 11. i want low end power
Old Jul 25, 2003 | 12:43 AM
wm5holla's Avatar
sorry for posting 3 times. but my 2 goals are : i know if i have new rings i wont burn oil and i wanted to UP my C/R too. would using a thiner head gastket work or millin my head
Old Jul 25, 2003 | 12:52 AM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">what is a pr3 head?</TD></TR></TABLE>
PR3 = B16/ITR/CTR Head Casting.
P72 = GSR
PR4 = LS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">what is the pistons to wall clearance being a lil bigger NOT cool? people on ht have told that ctr.itr have to high of adome to for a ls motor.. how i do find out the truth with out claying my motor?</TD></TR></TABLE>
The more Piston to Wall clearance you have, the more blow-by is increased. Theres a certain amount that your suppose/allowed to have. Spec.
Ive heard of people using ITR pistons in a LS motor but im not too sure about CTR pistons.. Claying would give you the definite answer.
JDM B16 P30 Pistons will give you 11:1 CR with OEM head gasket
JDM ITR Pistons: 10.8 CR OEM gasket
CTR Pistons: ~ 11.4 CR OEM gasket
Old Jul 25, 2003 | 01:06 AM
wm5holla's Avatar
the plan was rasie my CR gain HP
Old Jul 25, 2003 | 01:34 AM
95hbMatt's Avatar
throw in some jdm p30 pistons in there!
Old Jul 25, 2003 | 02:22 AM
JCushing's Avatar
if you want 11:1 then put in p30 pistons in. you can get them from hondaautomotivaparts.com (majestic) for pretty cheap. you might wanna get overbore if they are goin in a b18a.
Old Jul 25, 2003 | 08:33 AM
wm5holla's Avatar
p30 are b16 pistons? or?
Old Jul 25, 2003 | 08:34 AM
wm5holla's Avatar
i also i rember some one telling that i need to but bolts?
Old Jul 25, 2003 | 09:32 AM
95hbMatt's Avatar
yes they are jdm b16a pistons and most people will suggest getting ARP rod bolts and studs
Old Jul 25, 2003 | 06:33 PM
wm5holla's Avatar
Default Re: (95hbMatt)
WHATS GOING rate for those bolts and studs
Old Jul 25, 2003 | 06:59 PM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm5holla &raquo;</TD></TR><TR><TD CLASS="quote">WHATS GOING rate for those bolts and studs</TD></TR></TABLE>
im guessing you mean price...?
Rod Bolts:
$50 from http://www.inlinefour.com
Head Studs:
$150 im sure you can find better prices then 'above retail inlinefour' but heres a ball park...
Old Jul 25, 2003 | 07:22 PM
wm5holla's Avatar
thank yoy 10k
