Did i make a mistake. CX underdrive pulley on a d16z6 motor. I need you help gurus.
Old Jul 22, 2003 | 11:32 PM
shivic's Avatar
Default Did i make a mistake. CX underdrive pulley on a d16z6 motor. I need you help gurus.
I put the cx underdrive pulley on my z6 swap.
will this make my motor run off balance in high rpms. someone told me that it would.
the cx pulley is considerably lighter becuse it lack a spot for a/c and powersteering. i thought i was being rather clever shaving weight.
im going turbo in a week, do i need to put my z6 pulley back on asap.
oh yeah! my cx flywheel on in on a act clutch. that should be ok, right?
thanks for the help BOYS!!!!
Old Jul 23, 2003 | 06:49 AM
shivic's Avatar
Default Re: Did i make a mistake. CX underdrive pulley on a d16z6 motor. I need you help gurus. (shivic)
morning bump.
Old Jul 23, 2003 | 07:33 AM
sohc_boy's Avatar
alot of people don't like them because there is no dampening effect from it like the stock crank pulley. which could in turn cause premature bearing wear and failure.
Old Jul 23, 2003 | 07:36 AM
shivic's Avatar
Default Re: Did i make a mistake. CX underdrive pulley on a d16z6 motor. I need you help gurus. (sohc_boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy &raquo;</TD></TR><TR><TD CLASS="quote">alot of people don't like them because there is no dampening effect from it like the stock crank pulley. which could in turn cause premature bearing wear and failure.</TD></TR></TABLE>
what do you mean by dampening effect.
its can cause bearing wear to the crank?
Old Jul 23, 2003 | 10:04 AM
sohc_boy's Avatar
the stock pulley minimizes (dampens) vibration on the crank it is in effect a harmonic balancer. without it the crank can vibrate enough to kill bearings.
Old Jul 23, 2003 | 10:05 AM
thehatchninja's Avatar
um...it is a stock pulley....seems like it should be ok
Old Jul 23, 2003 | 10:07 AM
Plan B's Avatar
Default Re: Did i make a mistake. CX underdrive pulley on a d16z6 motor. I need you help gurus. (thehatchn
I don't think the gains are worth the posibility for error.
Old Jul 23, 2003 | 10:08 AM
shivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy &raquo;</TD></TR><TR><TD CLASS="quote">the stock pulley minimizes (dampens) vibration on the crank it is in effect a harmonic balancer. without it the crank can vibrate enough to kill bearings.</TD></TR></TABLE>
i have one on it. its just a cx. it weighs a few pounds less. do you think it's reducing vibration enough. or do i need to get the stocker.
Old Jul 23, 2003 | 11:49 AM
sohc_boy's Avatar
there are alot of opinions on this. i would just run the stock crank pulley because i believe that the undampened lite pulley will eventually cause problems.
Old Jul 23, 2003 | 11:51 AM
KRiS1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plan B &raquo;</TD></TR><TR><TD CLASS="quote">I don't think the gains are worth the posibility for error.</TD></TR></TABLE>
I haven't heard too many good things about changing the crank pulleys on hondas.
Old Jul 23, 2003 | 12:04 PM
MPower332TI's Avatar
Just because the pulley came off the cx doesnt mean it isnt dampened. Its still balanaced and you wont have any problems with it on your z6 motor. So i wouldnt worry about it. Stick with the cx pulley.
Old Jul 23, 2003 | 12:25 PM
sohc_boy's Avatar
i was under the impression u swapped your crank pulley for an aftermarket one, if u r running the stock one from the cx i wouldn't worry about it. its the aluminum light weight ones that can cause problems.
Old Jul 23, 2003 | 12:43 PM
shivic's Avatar
thanks for the help guys.
Im leaving it alone.
Old Jul 23, 2003 | 01:08 PM
built562's Avatar
just leave the cx pulley, its an oem lightend pulley that has a dampner.
Old Jul 23, 2003 | 01:38 PM
is there any pulleys like that for a b-series....i don't have ps or ac...and my pulley is chipped from shipping??
SOHC SPEED
Aug 11, 2008 04:03 PM
FMIDRC Racer
15
Apr 20, 2005 10:01 AM
importlegions
Jan 14, 2005 12:17 PM
shivic
Jul 23, 2003 10:22 AM
