Throw Out Bearing
Old Jul 22, 2003 | 11:13 PM
CircuitFG's Avatar
Default Throw Out Bearing
Ok, I searched on this. . but i didn't exactly find what i needed. . I just installed a new throw out bearing when i put in my new clutch and flywheel. It was just recently. Like maybe a month ago. Now, it kinda makes a little errr sound every now and then. Could i need to increase the play on the clutch?? Or do you think its a bad tob?? i dont want to replace it!
Old Jul 23, 2003 | 09:35 AM
CircuitFG's Avatar
Default Re: Throw Out Bearing (CircuitDA9)
ttt anyone????
Old Jul 23, 2003 | 09:55 AM
tilt's Avatar
does it make the whrrr sound when you fully depress the pedal? if there is too much travel it can cause that noise but you should have noticed it immediately after the install. Might want to try not fully depressing the clutch pedal when shifting to see if the cause is too much travel.
Old Jul 23, 2003 | 12:13 PM
CircuitFG's Avatar
Default Re: Throw Out Bearing (tilt)
its more of like a er (really quick short sound) when i engage the clutch while after shifting. . .
96gsrdb8
Transmission & Drivetrain
Aug 27, 2018 01:48 PM
Nataku
Sep 18, 2010 06:22 PM
CubbyChowder
16
May 4, 2010 02:17 PM
illi Adik
Honda S2000
May 11, 2009 07:24 PM
99FoxSi
Oct 1, 2002 10:00 AM
