New Clutch Installed Help
Hey guys, just installed the exedy racing clutch organic disc but when i step on the clutch pedel i cant go into gear, but with the car off i can go into gear. also when i idle at neutral and give a little gas it like boggs down and if i step on the gas it stalls out anyone have this problem before?
It sounds like the clutch is not releasing all the way which may be a simple adjustment issue. The rod at the pedal assembly is where you make the adjustment
JDM-FREAK
Dec 20, 2009 04:43 PM
