Help identify this tranny with LSD????
if you look through the differential housing and you can see through the other side with nothing in the way, then you have LSD, if you look through and there is a bar in the middle, then you don't have LSD.
it looks like it has LSD, but i still can't really tell. do you have any better pic's?
what's the tranny code on it? if it says S4C then its a 99-00 Si tranny. it might also be a type-r tranny which is basically an Si tranny with LSD.
as far as i know, it is NOT lsd equipped.
ive never seen that little hole in the middle of the bar running through the differiental but this is what i do know
if you see a bar, its not LSD
if you dont see a bar, LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
i don't know if that hole is in the middle of a bar or not. in the first pic of the differential it looks like the hole is in some kind of bar, but in the second pic the hole looks like its on the other side of the differential housing.
if you get some pics of the other side of the housing, i'd be able to tell.
what the hell is that?
after looking closer, there is nothing inside the differental. please explain to me what that metal plate that APPEARS to be running through the diff is?
i have no idea what the hell that thing is. maybe its an aftermarket LSD???
EDIT: or maybe they drilled a hole through the bar to make it look like LSD?? all i know is that thing is fugged up.
It has LSD, but unless someone added it to a 99-00 Si tranny, then it's not a 99-00 Si tranny.
They never came with factory LSD.
Ya, it's suppose to be a si tranny with aftermarket LSD. I'm trying to buy it but just wanted to see if any knew for sure if it was wat it seemed.
well from the pics you can determine that it does have a LSD.
it is also apparent that it is not a HONDA stock lsd like froma jdm b16 tranny.
it must be an aftermarket LSD.... and someonementioned Cusco, so I would search for ads or pics with Cusco LSD's to see if the internal section looks similar to the one pictured above.
to determine if it is a 99-00 Si tranny, I do not know how to do that... I dont know if there are markings on it but I do know that it SHOULD have a VIN plate on it and you had better have that there otherwise it is a stolen tranny possibly.... buyer BEWARE.
Nextelbuddy
Mar 31, 2003 07:40 PM
