thinking about going RWD or AWD
Old Jul 22, 2003 | 06:42 PM
TrickHonda98's Avatar
Default thinking about going RWD or AWD
are both possible. i've searched, found one thing on AWD didn't get any good reply's some people weren't sure on the AWD. I'd like
RWD. or AWD. any Possible? if I went AWD on my '95, I might have to use parts from the 1985-89 AWD staiton wagon wouldn't I? but I'd mostly also like to try RWD.
Old Jul 22, 2003 | 06:46 PM
Default Re: thinking about going RWD or AWD (TrickHonda77)
I don't mind swapping different motors either. (if I have to)
Old Jul 22, 2003 | 06:52 PM
hardcorepreston's Avatar
good luck I think doing the awd with the wagon might be easier working with an ef style since there in the same generation but still sounds hard.and going RWD would be a very custom job.the only RWD honda cars are the s2000 and the s600 and i think a few older ones.I belive someone did do a S2000 powered civic.but think your going to have to get rear axles it just sounds like too much.AWD and RWD civic just seem like a pain in the *** but with enouhg money anything is possible.if yopu want awd or rwd so bad you might as well give up on honda unless you can afford an S2000 or something.unless there is a way to do this I dont know about
Old Jul 22, 2003 | 06:57 PM
ATS*VEEE's Avatar
Default Re: (hardcorepreston)
awd is not worth it, the awd from the older civics is not the same kind of awd found on wrx's or lancer evos for instance.
Old Jul 22, 2003 | 07:01 PM
Default Re: (richierich)
HHMMM....... going RWD is just like AWD. the front driveshaft would have to be taken off. all I do is put on the set of rear axles from the old AWD station wagon and put a rear drive shaft on. OH... if it were only that simple. any other ideas anyone?
Old Jul 22, 2003 | 07:02 PM
all stock's Avatar
Default Re: (TrickHonda77)
if u want to go rwd, i suggest u buy a rwd car. unless ur filthy rich.
Old Jul 22, 2003 | 07:08 PM
Default Re: (all stock)
oh well. I guess my car will stay front wheel terror. $$$ is hard to get for a big job. oh well. i guess I'll forget about it. besides, there are certain advantages to FWD.
P.S. don't reply to this anymore, let all the good posts go to the top. I'm sorry, and I'm not trying to be A post *****.
spoonem2
Honda S2000
May 14, 2012 03:47 PM
usdm-honda-r18
Honda S2000
38
Mar 24, 2012 08:11 PM
realmike15
Honda S2000
51
Apr 24, 2011 05:17 PM
91akkord
Classic Hondas
Jan 27, 2008 12:40 PM
Shy_GuyAP1
Honda S2000
14
Jun 14, 2007 07:37 AM
