Sp00n oil pan/girdle
Old Aug 3, 2001 | 02:59 PM
yoshi234's Avatar
I shoot brides
Default Sp00n oil pan/girdle
does anyone know if this is still available from sp00n?
5L cast aluminum oil pan w/ 5 cap girdle
photo credit: honda hybrid board
Old Aug 3, 2001 | 03:06 PM
Mike M's Avatar
Founding Member
Default Re: Sp00n oil pan/girdle (yoshi234)
Still available but Mucho Dinero
Spoon uses them on their race engines
Old Aug 3, 2001 | 03:44 PM
EauRouge's Avatar
The oil pan/girdle costs about $5000 give or take a few hundred.
[Modified by 98LSTypeR, 5:09 PM 8/3/2001]
Old Aug 3, 2001 | 03:53 PM
MaxPowerIntegra's Avatar
Default Re: Sp00n oil pan/girdle (98LSTypeR)
The oil pan/girdle costs about $5000 give or that a few hundred.
wow... :speechless:
Old Aug 3, 2001 | 04:30 PM
Willard's Avatar
Default Re: Sp00n oil pan/girdle (George Knighton)
Strengthen the flat surface by adding webs?
Will
Old Aug 3, 2001 | 05:52 PM
Racer-X's Avatar
Default Re: Sp00n oil pan/girdle (Willard)
They are cooling fins and they are faced the right way it's just the way they took the picture. Remember the Honda engine sits hortizonal but in the pic it looks turned around only because its on engine stand for pictures.
The baffles are there to keep a good supply or oid on all the vital parts during high G corning and spinning engines between 8-12k all race long. It's hard to keep oil onto parts spinning that fast and also in high G corners. This oil pan is used in there N1 cars
Old Aug 4, 2001 | 08:37 PM
lucas569's Avatar
$5k!!!!???? thats insane! thats way too steep for that, is that really he price?
jeez and i thought the moroso pan was overpriced
Old Aug 4, 2001 | 09:34 PM
JDM_DOHC_SiR's Avatar
New User
Yep That Baby goes for 260000 yen !!!! But with the yan to dollar rate now at 122 to the dollae that "ONLY"!! Costs about 2200$ Small change for some of us hahahah Yea Right But I would give it the for cool points
Old Aug 4, 2001 | 09:58 PM
EauRouge's Avatar
Default Re: Sp00n oil pan/girdle (JDM_DOHC_SiR)
That price is only for the girdle not the oil pan or the other way around. Anyways, oil pan and girdle are TWO SEPARATE items. Trust me, I have seen the Spoon catalog.
And you can't use another oil pan because those clever Spoon guys made sure part of the support for the block from girdle was built into the oil pan itself. Hence the two items are INSEPARABLE.
Old Aug 4, 2001 | 10:03 PM
New User
ONE Word TYPO But Last week when I was at Type One (Spoons new retail shop) They Sad "260000" YEN
Old Aug 6, 2001 | 07:40 AM
ZygSpeed's Avatar
The Mugen baffled oil pan is in the $250 (or slightly less) range, and the R already has a partial "griddle".
Old Aug 6, 2001 | 09:05 AM
Jimmy L's Avatar
Default Re: Sp00n oil pan/girdle (zygspeed)
Also remember that cooling fins do not need air flowing across them to be effective, although it helps. The fins create a larger surface area which dissipates heat better. Not trying to call anybody down, I just thought I'd add that.
Old Aug 6, 2001 | 10:23 AM
Lip's Avatar
Lip
http://www.moroso.com/catalog/catego...?catcode=11111
SP GARAGE
Jun 11, 2013 09:01 AM
latinman07
Jan 2, 2013 10:01 PM
K20A2 5 lug EG
Aug 6, 2008 11:50 AM
