Clutch acting up!!!
Old Jul 22, 2003 | 05:52 PM
FK00GSR's Avatar
Default Clutch acting up!!!
Hey everyone, everytime I let my clutch out I hear a clicking sound (Metal or Plastic not sure). So i figured ill spray some WD-40 down there and it went away for a day and then comes back. Does anyone know what this could be? Please help it is really annoying. It clicks almost at the point where your clutches catches when letting out.
Old Jul 24, 2003 | 04:33 PM
FK00GSR's Avatar
Default Re: Clutch acting up!!! (FK00GSR)
anybody???
Old Jul 25, 2003 | 04:12 AM
JimBlake's Avatar
Have someone work the clutch pedal while you listen under the hood. It might actually be the slave cylinder piston rod or something like that, & the sound just travels back to the pedal.
Maybe grease the ball & socket in that rubber boot at the slave cylinder?? If it's really at the clutch pedal, try some grease instead of WD40. It'll last longer.
Old Jul 25, 2003 | 09:25 AM
redlinegsr's Avatar
Possible the release or throwout bearing. When you hear the click is it effecting the clutch engagement at all?
Old Aug 3, 2003 | 05:34 PM
FK00GSR's Avatar
Default Re: Clutch acting up!!! (redlinegsr)
ok i found out that it is the master clutch cylinder. i am not sure if i need to take it apart and grease it up and reinstall or if i need a whole new one. If i do need a new one do you think its worth getting it from the dealer or should i get one at a junkyard. Actually are junkyards really that much cheaper then the dealership?
Old Aug 3, 2003 | 05:50 PM
Passaudi1.8t's Avatar
New User
Buy a new master cylinder... you have no idea what the used one has been through. When in doubt, always buy new
Old Aug 3, 2003 | 06:33 PM
FK00GSR's Avatar
Default Re: Clutch acting up!!! (vtecivicex)
Does anyone know where I can find out how to replace this. Is there anyway websites on how to's. I already tried the search feature as well as team-integra.net Would the Helms manual help anybody.
DenisR
Feb 19, 2016 05:09 PM
Javelin
Sep 29, 2015 07:17 PM
curtie94
Apr 10, 2011 12:47 PM
D16Clunkin
13
Dec 22, 2006 05:43 AM
Komakazi_830
Dec 5, 2005 04:53 PM
