Results from running with too much ignition timing
Old Jul 22, 2003 | 03:17 PM
earl's Avatar
Default Results from running with too much ignition timing
We had a perfect air/fuel ratio in our tune-up but some how the ignition map got pushed to 30 degrees advance. The CRX ran strong until about the 1000' mark and the motor just nosed over. Still ran 156 mph on the run but this was the results...
The before picture
BTW, our regular tuner did not do this...
Old Jul 22, 2003 | 03:19 PM
Sonny's Avatar
Default Re: Results from running with too much ignition timing (earl)
OUCH
Old Jul 22, 2003 | 03:20 PM
b16ahybrid's Avatar
Default Re: Results from running with too much ignition timing (Sonny)
What a beautiful picture (before)....
Like sonny said.......ouch....
156mph nice speed
Old Jul 22, 2003 | 03:23 PM
earl's Avatar
Default Re: Results from running with too much ignition timing (b16ahybrid)
The Pauter rod looked like a candle with aluminum drippings running down the side
Old Jul 22, 2003 | 03:30 PM
Drag R's Avatar
maybe you should have advanced it more
Old Jul 22, 2003 | 03:33 PM
LJR-LUDE01's Avatar
what kind of piston is that, look like the CP.
Old Jul 22, 2003 | 03:35 PM
Boostfed's Avatar
New User
DAMN that is SCARY! My buddy tuned his car to 590whp but to get their they played with the ignition timing, YEAH it melted a piston too, had to go from 81.5mm to 84.5mm . Good luck the rest of the year and only let Ben tune your ****.
Old Jul 22, 2003 | 03:37 PM
earl's Avatar
Default Re: (LJR-LUDE01)
WAS a CP
Old Jul 22, 2003 | 03:40 PM
ImportechPerformance's Avatar
Default Re: (earl)
bye bye cp piston
Old Jul 22, 2003 | 03:44 PM
turbolshatch's Avatar
Default Re: (TheRedSkoolingBus)
sorry for the noob question but what does the car normally run?
Old Jul 22, 2003 | 03:48 PM
earl's Avatar
Default Re: (turbolshatch)
low 20's
Old Jul 22, 2003 | 03:52 PM
Mase's Avatar
Default Re: (earl)
damn earl, that sucks, i hope it was a mistake about the timing i didnt even run 30 degrees of advance at 10 psi on my car. sorry to hear.
Old Jul 22, 2003 | 04:11 PM
earl's Avatar
Default Re: (Mase)
No, the 30 degrees was not done on purpose.
Old Jul 22, 2003 | 04:16 PM
LsTurbo91's Avatar
Default Re: (earl)
Did you hear it knocking/detonating by any chance? I guess in this case it wouldnt have mattered, going that fast with that much HP.
Old Jul 22, 2003 | 04:19 PM
alpha's Avatar
Any pictures of the rods?
Old Jul 22, 2003 | 04:29 PM
SuperTeg95's Avatar
Default Re: (0x64)
how did it advance itself? Would you mind posting a pic of the rod?
Old Jul 22, 2003 | 04:33 PM
earl's Avatar
Default Re: (SuperTeg95)
I buffed off all the aluminum from the Pauter and it looks new. No blueing of the metal and pin fit is still perfect. Got to love the Pauter
Old Jul 22, 2003 | 04:35 PM
SuperTeg95's Avatar
Default Re: (earl)
Sounds like a good rod
Old Jul 22, 2003 | 04:37 PM
earl's Avatar
Default Re: (LsTurbo91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsTurbo91 &raquo;</TD></TR><TR><TD CLASS="quote">Did you hear it knocking/detonating by any chance? I guess in this case it wouldnt have mattered, going that fast with that much HP.</TD></TR></TABLE>Heard nothing and felt the power drop off at 1000 foot mark. No warnings
Old Jul 22, 2003 | 05:08 PM
rOby's Avatar
Default Re: (earl)
ill buy it from you
Old Jul 22, 2003 | 05:15 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: (rOby)
what car is this?
Old Jul 22, 2003 | 07:00 PM
Jared's Avatar
Default Re: (turbotypeR)
I'm guessing that's from their race car.
Old Jul 22, 2003 | 07:01 PM
Mase's Avatar
Default Re: (Jared)
yes, its from their race motor.
Old Jul 22, 2003 | 07:19 PM
earl's Avatar
Default Re: (Mase)
All that damage in about 2 seconds...no warning
Old Jul 22, 2003 | 07:21 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: (earl)
OMFG
