turbo throttle body
i installed the JG manifold with a 70m tb on a stock B16 and lost alot of power and torque. i tried to re-tune with no avail.
i just broke in my built GSR with the JG manifold on it but with a stock B16 TB. i will add the 70mm tb to see if there is a change in the power band. i'll leave it on even if i lose power becuz the car is not dyno tuned yet. i'll let you know the results as soon as i get it tuned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">You'll only see gains if the throttle body is a restriction in your setup. I've seen 500whp on a 65mm.</TD></TR></TABLE>
I have seen 500whp with a stock 00 Si B16A TB.
....Mine
....Mine
