wiring y8 dizzy to 91 dx harness??
iam swaping in the d16z6 into my car. the motor is a z6 with a y8 head and y8 distributor. how would i go about wiring the dizzy to my harness?
searched and didnt find anything to help me.
thank you
thank you
dont think it will work. y8 dizzy is obd2. and my car is wired for obd0. why do people say that you have to modify the 4g si distrubitors to make them fit? mine just bolted right up...
The 4g distributor bolts to the Y8 head without modifications, but it won't to the Z6 head. You can run the Y8 distributor if you convert to OBD-I (yes it WILL work).
Pokemon, get you facts straight before posting.
Spreading false information is no help.
OBD2 distributor can indeed be used on an OBD1.
For the original poster:
I am assuming you already converted to MPFI, right?
So if you already have that wiring part done, you should have 7 wires coming out of the distributor. If you have 5 wires, you have no business trying to install the OBD2 distributor.
It would be nice if you could give detailed info as to what you have done, so we don't have to guess how to help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pokemon »</TD></TR><TR><TD CLASS="quote">you can use the y8 dizzy if you convert to obd-2 ;] not 1</TD></TR></TABLE>
Don't tell me it can't be done, because I DID IT...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spaceballs the lunch box »</TD></TR><TR><TD CLASS="quote">
It would be nice if you could give detailed info as to what you have done, so we don't have to guess how to help you.</TD></TR></TABLE>
no business ehh... hmmm in my sig it happens to say "1.5 mpfi" hmmmm yup i did the mpfi swap. now i am swaping in the z6 block with the y8 head 4g si dizzy, 91 si ecu. mpfi swap is and has been done and working properly. i am planning on using the 4g dizzy cuz it bolts right on to my y8 head.
ohh and obd2 gets a big
from meh in an 88-91
Oh see!
If you had mentioned that you were using the 91 Si ECU (PM6) I would not have typed what I did. The PM6 will not work with the OBD2 distributor.
So, then you are set. You have a Y8 head, the OBD0 distributor bolts right on without modifications, and you don't need the OBD2 distributor.
So this makes this post kind of pointless, doesn it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spaceballs the lunch box »</TD></TR><TR><TD CLASS="quote">Oh see!
So this makes this post kind of pointless, doesn it?</TD></TR></TABLE>
Not pointless, cause you can get guys like me that will recomend that you DO convert to OBD1, and use the Y8 dizzy.
So
to you luchbox. BTW that movie is the BEST ever
So
im glad i didnt try to rewire that obd2 dizzy to my obd0 ecu. and feeling pretty good that i choose to build my motor with the y8 head, cuz now i dont have to modify my dizzy to make it fit. thanks for your somewhat useful info Spaceballs the lunch box
peace
peace
twizted-myatt
May 31, 2011 02:34 PM
