Bad throttle reponce on my 98' ITR???(w/ rebuilt motor)
Old Jul 22, 2003 | 12:15 PM
jdmitr98's Avatar
Default Bad throttle reponce on my 98' ITR???(w/ rebuilt motor)
My motor was just rebuilt about 2K miles ago and every since then it has just become a hassle, the throttle responce is just not there like it use to be with the stock block- and I know this is not right- so what could cause this?
I just had a compression and leakdown test done and the #'s were good-
leakdown was 5% on all 4 cylinders
compression: 215,212,214,215
Old Jul 22, 2003 | 12:21 PM
onyx00's Avatar
Default Re: Bad throttle reponce on my 98' ITR???(w/ rebuilt motor) (jdmitr98)
Maybe valve adjustment. How is the power? Rough idle?
Old Jul 22, 2003 | 12:22 PM
RTW DC2R's Avatar
Are you using a different computer by chance? If not, sounds like it could just be something with the TPS or maybe the throttle cable is loose. Did you change injectors?
Old Jul 22, 2003 | 05:17 PM
jdmitr98's Avatar
Default Re: Bad throttle reponce on my 98' ITR???(w/ rebuilt motor) (onyx00)
There semes to be no power right before vtec kicks in, and no the car does not idle rough.
Old Jul 22, 2003 | 05:58 PM
flex97itr's Avatar
i would check your timing, both cam and ignition timing
Old Jul 22, 2003 | 06:20 PM
98itR484's Avatar
Default Re: Bad throttle reponce on my 98' ITR???(w/ rebuilt motor) (flex97itr)
has the car been tuned? that would make a difference.
Old Jul 23, 2003 | 12:03 AM
jdmitr98's Avatar
Yes the timing use to be retarted and then I had it switched back to stock and the cam gears as well.
Old Jul 24, 2003 | 02:28 PM
jdmitr98's Avatar
Old Jul 24, 2003 | 07:47 PM
Michael Delaney's Avatar
you need your ignition and fuel maps (partial throttle tuning) redone.
the hondata guys can tell you that the stock ignition map is fairly "retarded" in the lower engine loads and advancing the base timing helps but when you redo the 3D ignition map, it helps the laziness of the repsonse from 3-5 K rpm tremendously.
Tuan who didn't know that Technosquare (G-Force) dumped their Honda arm of Techtom to Hondata....
tagar89
Nov 4, 2014 05:18 PM
legendre
Honda CR-V & Element
66
Feb 22, 2014 12:21 AM
freakasis
Feb 24, 2007 01:27 PM
GsrTurboCRX88
Aug 1, 2006 08:27 PM
zensoku207
Mar 21, 2005 10:49 PM
