Guys i need help Big TIME!!!!!
Old Jul 22, 2003 | 11:29 AM
S2k ALeN's Avatar
Default Guys i need help Big TIME!!!!!
I recently did a swap, putting a jdm b18c1 in my 1993 hatch (DX non-vtec). We finished the swap fast and easy. (we wired new wires from the ecu to the vtec pressure switch and the silonoid). When i drove it the first time and hit vtec, WOW the car flew. I loved it. After i punched the car about 3 times. The Check engine light turnd one. Also the car was now ideling at 2500 rpm. Now when i punched the car the rpm would rise slower and it would take a long time to hit vtec.
HELP PLEASE !!!!
Old Jul 22, 2003 | 12:08 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Guys i need help Big TIME!!!!! (CBACK91)
Check your ECU for codes, and see what it wrong.
Blaze
Old Jul 22, 2003 | 12:18 PM
S2k ALeN's Avatar
How do u check ecu for codes
Old Jul 22, 2003 | 12:36 PM
NonovUrbizniz's Avatar
Loved
Default Re: (CBACK91)
there is a little plug that sits under your pass. side dash (right above the ecu)...
It's a 2 wire connector that doesn't plug into anything else (just a plastic holding bit on mine). you jump (put a paper clip in both holes) the clip...
you then turn the accesory power on and count the blinks of the check engine light...
They should be fast then slow or slow then fast can't remember... but you count each group... the first group (of flashes be it fast first or slow first) is the first number... the second group is the second number...
So for example if it blinks fast 2 times then slow 7 times you have thrown code 27... got it...
If that's not clear enough I'm sure someone else can provide a clearer discription or probobly pics.
Old Jul 22, 2003 | 12:41 PM
S2k ALeN's Avatar
ok thanx i got it
nicko360
Oct 27, 2007 09:27 AM
B20_SI_CRX
Jun 3, 2005 09:03 PM
Jdm_Honda_Integra
Oct 25, 2004 06:59 PM
-[95cxhatch]-
Aug 18, 2003 08:01 AM
Metal_SOL
Jul 16, 2002 10:23 PM
