How to remove swirl marks?
Old Jul 22, 2003 | 10:45 AM
StinkyTofu's Avatar
Default How to remove swirl marks?
I am thinking of just taking my car to a body shop and having them detail my whole car and take out the swirls. But before i go spend a few hundred bucks, i was wondering what you guys had for advice. Basically, i don't wanna mess up my paint job trying to take the swirls away, so help me out please
Old Jul 22, 2003 | 11:00 AM
-Gambit-'s Avatar
Default Re: How to remove swirl marks? (StinkyTofu)
wash your car then clay it, then use some swirl remover on your car, then wax it. And say buh bye to swirls.
Old Jul 22, 2003 | 11:04 AM
StinkyTofu's Avatar
Default Re: How to remove swirl marks? (gambit33)
What kind of clay do you recommmend? I tried using the meguiars once, and that stuff just stuck onto my car and it was hard to remove. Ever since that, i've been to scared to try it again.
Old Jul 22, 2003 | 11:05 AM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gambit33 &raquo;</TD></TR><TR><TD CLASS="quote">wash your car then clay it, then use some swirl remover on your car, then wax it. And say buh bye to swirls. </TD></TR></TABLE>
There you have it, that's what I would do.
Old Jul 22, 2003 | 11:11 AM
-Gambit-'s Avatar
i use clay magic for claying the car. And meguiars for the wax, and swirl remover.
Old Jul 22, 2003 | 11:13 AM
StinkyTofu's Avatar
Does using that method remove the swirls temporarily? Or is it permanent? Aren't there some swirl removers that are the "filler" type?
Old Jul 22, 2003 | 11:18 AM
-Gambit-'s Avatar
it will remove the swirls for a long time, but the more you wash your car and drive it, the quicker the swirls will come back. I need to do that again to my own car. I havent done it to my car for about 6 months now. But trust me your paint will look new again, and the best part when you drop a towel or something on the hood it will slide off.
Old Jul 22, 2003 | 11:48 AM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">What kind of clay do you recommmend? I tried using the meguiars once, and that stuff just stuck onto my car and it was hard to remove. Ever since that, i've been to scared to try it again. </TD></TR></TABLE>
Did you prep the clay first? You want to knead it, like dough before using it, to soften it up, and be sure to use plenty of water or spray to keep the surface wet.
Old Jul 22, 2003 | 11:52 AM
IntEGNYC's Avatar
Default Re: How to remove swirl marks? (rodrez)
You have to use detailing spray to lubricate the clay. A tip is to use small chunks at a time. That way you can toss it out if your clay gets contaminated. If your clay falls on the ground, toss it.
the meguires and mother's 3 stage cleaning systems will hide the swirls but its only temporary and will require 3 coats (for each stage respectively).
the truth is, you cant beat a good detail job where they compound the entire car. Its worth it if your car is a few years old and needs a sprucing.
Old Jul 22, 2003 | 12:02 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">
Did you prep the clay first? You want to knead it, like dough before using it, to soften it up, and be sure to use plenty of water or spray to keep the surface wet. </TD></TR></TABLE>
Let me add to this.
Before you clay, use Dawn diswashing liquid to take off any old wax. After you rinse the suds off, do not dry the car off. Leave it wet and then use the spray during the clay process.
Old Jul 22, 2003 | 12:10 PM
ken-e's Avatar
Default Re: How to remove swirl marks? (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">You have to use detailing spray to lubricate the clay. A tip is to use small chunks at a time. That way you can toss it out if your clay gets contaminated. If your clay falls on the ground, toss it.
</TD></TR></TABLE>so I guess you cant re-use the clay right??
Old Jul 22, 2003 | 12:15 PM
ken-e's Avatar
Default Re: How to remove swirl marks? (ITRbroham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRbroham &raquo;</TD></TR><TR><TD CLASS="quote">
Let me add to this.
Before you clay, use Dawn diswashing liquid to take off any old wax. After you rinse the suds off, do not dry the car off. Leave it wet and then use the spray during the clay process.</TD></TR></TABLE>I thoguht dishwashig soap was bad for your paint?, maybe its just to get the wax off right???
Old Jul 22, 2003 | 12:17 PM
ITRbroham's Avatar
shit post warrior
Default Re: How to remove swirl marks? (eg6ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ken &raquo;</TD></TR><TR><TD CLASS="quote">I thoguht dishwashig soap was bad for your paint?, maybe its just to get the wax off right???</TD></TR></TABLE>
Nope, just bad for wax!
Old Jul 22, 2003 | 12:18 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ken &raquo;</TD></TR><TR><TD CLASS="quote">so I guess you cant re-use the clay right??</TD></TR></TABLE>
I have before, when I ran out. My friend needed help cleaning up his car, so I reused some. I would knead the clay inside out a bunch of times, and it was still effective
Old Jul 22, 2003 | 12:19 PM
ken-e's Avatar
I have before, when I ran out. My friend needed help cleaning up his car, so I reused some. I would knead the clay inside out a bunch of times, and it was still effective</TD></TR></TABLE>thanks, I've been wondering about that for a while
Old Jul 22, 2003 | 02:12 PM
Denny's Avatar
use this stuff called "satin creme" it has like clay additives, sealent, and carnuba wax. took all my swirl marks away.
Old Jul 22, 2003 | 02:17 PM
StinkyTofu's Avatar
Default Re: How to remove swirl marks? (Denny)
Wow, thanks for all the help guys. Definitely some good information to know in this thread. I will definitely try this out when i have a day that i don't have to work. I anticipate this taking a good 6-8 hours to do...boy will that be fun =\
Old Jul 22, 2003 | 05:49 PM
gamby's Avatar
I my experience (semipro detailer), clay doesn't really remove swirls. It smooths out the paint surface beautifully, though.
Meguiar's Swirl Remover and a random orbital buffer after claying will greatly reduce swirls, though.
biggusf
Feb 23, 2005 12:53 PM
Honda_18
25
Dec 5, 2004 02:38 PM
AL ASPIRATED
May 11, 2004 05:50 AM
gribbs
Apr 27, 2004 11:14 AM
Denny
Jul 12, 2003 09:09 PM
