Engine wont start... Problem?
Old Jul 22, 2003 | 07:57 AM
Mr.SpiLLz's Avatar
Default Engine wont start... Problem?
This is not really a honda tech question rather an engine in general question... My 88 buick park avenue wont start, at first i thought it was the battery because last night i left the interior light on all night... So i started to charge it with my crx, now all the lights and power stuff work but the car still wont start and its making a really loud grinding scratching sounds and the belts try to turn but wont...What can be the problem , the starter? thanks for any help...
Old Jul 22, 2003 | 08:33 AM
SIRX's Avatar
Default Re: Engine wont start... Problem? (MrSpiLLz)
the grinding noise your talking about. could it be the solenoid clicking? most gms do this when the battery isn't charged enough
Old Jul 22, 2003 | 08:37 AM
JimBlake's Avatar
I bet the 88 Buick starter draws a bit more power than a CRX starter...
First make sure all the battery cables are attached solid, clean up the corrosion at both ends, all that obvious stuff.
If the buick battery will hold a charge, then maybe all you have to do is leave the crx running for a while to charge the buick thoroughly. Don't you have a battery charger?
If the buick battery won't hold a charge, you might be SOL. The crx alternator might not have enough power to drive the buick starter. So use the crx to drive to AutoZoned & buy a battery.
I can't hear the 'really loud grinding scratching sounds' from here, but maybe your starter pinion gear is chewed up??
xander1100
Oct 18, 2009 07:56 PM
J9D6M
Dec 18, 2007 10:40 AM
jorge59la
Sep 16, 2007 06:28 PM
AVXHATCH
12
Jul 6, 2003 05:08 AM
Superhatch
Dec 24, 2002 02:36 AM
