primary vs secondary o2 sensor
Old Jul 22, 2003 | 01:29 AM
Loveless's Avatar
Default primary vs secondary o2 sensor
is it the same thing? can I swap them?
Old Jul 22, 2003 | 03:43 AM
PM-Performance's Avatar
Default Re: primary vs secondary o2 sensor (Loveless)
i tihnk you can , but im not toally ure.
Old Jul 22, 2003 | 05:35 AM
VTEC-DA's Avatar
Default Re: primary vs secondary o2 sensor (itr206)
Primary actually does all the work, all the secondary does is relay the signal to the ECU.
Old Jul 22, 2003 | 05:48 AM
Default Re: primary vs secondary o2 sensor (VTEC-DA)
but are the sensors thme sleves the same? ill check when i get a chance, i have both my sensors out at the moment , ill check the part numbers, i tihnk the second only does that job becuase where its hooked into the ecu , i could be wronh though
Old Jul 22, 2003 | 10:10 AM
AzG35's Avatar
I believe they are the same internally, but the wires on the secondary are longer.
Old Jul 22, 2003 | 10:24 AM
MooreBoost's Avatar
Default Re: primary vs secondary o2 sensor (AzSi22)
You can switch them, but if you go to Acura to buy one they will ask you if you want the primary or secondary. The primary sends info to the ecu to help tune the a/f ratio. The secondary is purely for emissions.
gmoore
HONDA RR
Sep 16, 2005 03:53 PM
mrduque
May 5, 2004 06:06 PM
NeXtLeVeL_TyPe_R
Mar 19, 2002 03:54 AM
Pinhead
Jan 13, 2002 05:17 PM
