Problem with throttle/SAFC.
Old Jul 21, 2003 | 10:39 PM
Goldfingiz's Avatar
Default Problem with throttle/SAFC.
Hey guys, I'm having a little problem. When my car is off, the throttle measurement on the SAFC reads 0%, and when I floor it, it reads 100% (works just fine).
While i'm driving, the throttle reads 0% when I'm off the throttle, but when I floor it, it only registeres 80% which probably means it's not switching over to the high throttle fuel map. Any ideas what this could be?
Any, and all help is very much appreciated!
Old Jul 22, 2003 | 07:13 AM
Goldfingiz's Avatar
Default Re: Problem with throttle/SAFC. (Goldfingiz)
Old Jul 22, 2003 | 12:13 PM
Blaze45's Avatar
Brrraaaap!
I have read this happening b4. Someguy would pin it and the throttle reading would only read 92% or something when he was crusing... But when at idle, he would floor it and it would jump to 100%. Bump cause I would like to know what causes this....
Blaze
Old Jul 22, 2003 | 01:26 PM
ion_four's Avatar
umm yeah, it sounds like you need to adjust your TPS sensor. If you haven't already removed the butt-nuts (fasters with no heads) you should cut a groove in them so you can use a screw driver, or just cut them and replace them with machine screws...if this doesn't make sense, do a search since I'm sure it's out there...
UKintegra
Jun 8, 2011 12:32 PM
silverdcteg
May 16, 2011 07:30 AM
Des9255
Oct 24, 2005 09:58 PM
zilverz
Jan 27, 2003 12:25 PM
Smashback
Dec 16, 2001 06:37 PM
