Skunk2 Short Shifter
Old Jul 21, 2003 | 08:50 PM
DownBoyDown's Avatar
Default Skunk2 Short Shifter Experience
Ive heard a lot of good things about the Skunk2 short shifter and ****, but have had less then great experience with the combo. Shifting now takes more muscle to change gears at low speeds. Also Im not sure if the short shifter is supossed to fix this but shifting still feels very notchy as it did before. Does anyone have experience with the Skunk2 and what were youre impressions? Also how much did you torque down the through bolt on the shifter? Would bushings help to cure the notchy feeling of the shifter? Any help would be appreciated!
Old Jul 22, 2003 | 05:35 AM
Neeko's Avatar
Default Re: Skunk2 Short Shifter Experience (DownBoyDown)
I just had my skunk2 installed on Friday and so far I really like it. I have the spoon shift **** with it and I actually prefer the stiffness of the shifts over stock. Throws are quite a bit shorter than stock; although now I wish I had taken an overhead picture before and after to show the difference in throw lengths.
in my book
Old Jul 22, 2003 | 06:31 AM
pnthr30's Avatar
Default Re: Skunk2 Short Shifter Experience (Neeko)
poly bushings = ($10 well spent)
Old Jul 22, 2003 | 11:53 AM
SupaTegRS's Avatar
Default Re: Skunk2 Short Shifter Experience (pnthr30)
loosen the bolt that goes through the linkage underneath the car......I had the same problem.
I LOVE my sk2 shifter and ****.....makes the shifts sooo much smoother and shorter.
skunk2 shifter/**** =
Old Jul 22, 2003 | 03:03 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I would suspect you didn't install the hardware correctly on the through-bolt. It should have come with 2 small spacers, and you install one on each side of the shifter. This allows the bearing to pivot against those spacers and it won't matter how tight the bolt is, the shifter will still move the same.
Old Jul 22, 2003 | 03:35 PM
SupaTegRS's Avatar
Default Re: Skunk2 Short Shifter Experience (PatrickGSR94)
it actually did matter for me.......i cranked that sucker down the first time i was under the car. Got in for a test drive and could barely move the damn shifter. I double checked all the spacers, and they were in the right place, i had just pinched the linkage together too much. Like Patrick said, the shifter is not bothered by overtightening because of the spacers against the bearings; however there will be too much friction between the spacers and the the shift linkage bar that goes to the transmission. That is where the problem is. Simply loosen the bolt to allow the linkage to pivot easier.
It can make a difference if you overtighten the linkage bolt, at least on the skunk2. Hope this helps
Old Jul 22, 2003 | 03:42 PM
Aaron M's Avatar
Default Re: Skunk2 Short Shifter Experience (SupaTegRS)
yea, you tighten the bolt down to much. i made mine hand tight, then like half a turn with the wrench
Old Jul 22, 2003 | 04:01 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupaTegRS &raquo;</TD></TR><TR><TD CLASS="quote">it actually did matter for me.......i cranked that sucker down the first time i was under the car. Got in for a test drive and could barely move the damn shifter. I double checked all the spacers, and they were in the right place, i had just pinched the linkage together too much. Like Patrick said, the shifter is not bothered by overtightening because of the spacers against the bearings; however there will be too much friction between the spacers and the the shift linkage bar that goes to the transmission. That is where the problem is. Simply loosen the bolt to allow the linkage to pivot easier.
It can make a difference if you overtighten the linkage bolt, at least on the skunk2. Hope this helps </TD></TR></TABLE>
Well it's kind of hard to explain... say you tighten down the bolt and have spacers on both sides of the shifter bearing. Okay since the bolt is tight, the spacers are pressed against the shift linkage, and so the spacers and linkage move together as one. Now since the spacers are pressed against the bearing, the bearing's inner race, the spacers, and the linkage, all move as one. So that's the point of having the bearing in there in the first place. The bearing's outer race moves (pivots) as one with the actual shifter, as you move it forwards or backwards, but the bearing's inner and outer races can move (rotate) independently of each other.
At least this is how it works on my AutoZone shifter, and from looking at the Skunk2 hardware, it should be the same way (although I haven't installed one myself). The spacers press against the bearing's inner race, and the outer race is free to move with the shifter, so it shouldn't matter how tight the bolt is.
I guess an illustration would help but I don't have one.
Old Jul 22, 2003 | 05:09 PM
SupaTegRS's Avatar
yes, i see what you are saying......however, the linkage must still pivot back and forth when the shifter is moved. If you try overtighten, the bracket on the end of the shift linkage bar (the one going to the tranny) gets pinched together and wont allow easy pivoting because of the friction between the bracket the thewashers or spacers. Even though the bearings are free to move, the whole assembly is not.
This is what worked for me, and solved my problem with notchy/rough shifting after i installed my shifter.
Not trying to be a smart ***, just telling what worked for me.
Old Jul 22, 2003 | 07:09 PM
Hey thanks for all the replies. Ill try to loosen up that bolt this weekend when I get some time.
Old Jul 24, 2003 | 07:47 AM
LS stretch's Avatar
im looking to buy a short throw for my 01 ls integra... n e one now of n e good places where i could get a reasonably priced one?
Old Jul 24, 2003 | 11:57 AM
obsidianG35's Avatar
Which bolt would that be? Is it where the poly bushings are? Would I need to remove my exhaust again to get access to this bolt?
Old Jul 24, 2003 | 03:03 PM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neeko &raquo;</TD></TR><TR><TD CLASS="quote">I just had my skunk2 installed on Friday and so far I really like it. I have the spoon shift **** with it and I actually prefer the stiffness of the shifts over stock. Throws are quite a bit shorter than stock; although now I wish I had taken an overhead picture before and after to show the difference in throw lengths.
in my book
</TD></TR></TABLE> me too, spoon black **** and skunk2 shifter = perfection. I also threw on ES poly bushings.
Old Jul 24, 2003 | 03:26 PM
beaterman's Avatar
upgrade your bushings. its well worth it. i have the skunk2 with the greddy **** and poly bushings. great buy.
ej6fade
12
Apr 12, 2014 06:36 AM
vtek9
Oct 7, 2007 05:21 PM
PinoyCivic
10
Feb 21, 2006 01:42 PM
ItrpwrdCrx
Oct 2, 2004 11:50 AM
Can'tCatchMe
Jun 27, 2004 01:27 PM
