Thermostatic switch on EF w/ LS???
I did a swap in my buddies car. The sensor I've now come to know as the thermostic switch on the back of the block I have no provisions for on my DX-MPFI harness. I would assume all engines have such a sensor to turn the fan on and off. From where do I relocate the wires? I know this has to have been done several times before. Thanks in advance, CRXBart
yeah can you just replace the original clip so it plugs in each little obd prong or is there a proper wire to go with each obd1 prong in the plug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altoid »</TD></TR><TR><TD CLASS="quote">yeah can you just replace the original clip so it plugs in each little obd prong or is there a proper wire to go with each obd1 prong in the plug?</TD></TR></TABLE> I had to read that like 5 times and i still dont know for sure what u mean...but all u have to is depin the old OBD0 white plug and put those pins into the OBD1 grey plug. Thats what i did.
Ok the white plug on the left side of the cylinder head? Under and to the front of the distributor???
UniqueX707
Jun 11, 2013 01:09 AM
