Explain to me what is a NON Spring disc clutch ??
Old Jul 21, 2003 | 07:46 PM
mz3bo's Avatar
Default Explain to me what is a NON Sprung disc clutch ??
Can someone explain to me what is non sprung clutch disc, I know it has not spring, but what's the difference and + ou - ? Also, what is the use of using a non-oem pressure plate when using 4 or 6 puck act clutch... i really don't like the hard pedal and was wondering what can happen if I use the oem pressure plate.
Thanks
Old Jul 21, 2003 | 08:34 PM
SuperSteve's Avatar
New User
25 Year Member
Default Re: Explain to me what is a NON Sprung disc clutch ?? (mz3bo)
Well an unsprung disc is just that, no srpings which cause a harsher engagement.
And the use of an OEM pressure plate is not good if you are making a lot more power and torque than a stock . It will probably not last very long.
Old Jul 22, 2003 | 05:01 AM
Lsos's Avatar
The torsional springs in the clutch allow it to flex a little to absorb some of the shock of engagement. I don't really understand why, but I guess the four puck and six puck clutches can hold more torque.
Old Jul 22, 2003 | 09:18 AM
MikeSarr_GSR's Avatar
Default Re: Explain to me what is a NON Sprung disc clutch ?? (Lsos)
THUD!!
phyzJunkieCivic
Dec 1, 2006 04:16 PM
Civic168
Jun 30, 2004 09:38 PM
vtecdamian
Nov 27, 2003 12:26 PM
Wiseguy619
Nov 1, 2003 01:01 PM
ScottEK
May 27, 2003 07:11 PM
