JDM TYPR-R ECU,in 00 US GSR w/ JDM R MOTOR???????
Old Aug 3, 2001 | 08:19 AM
SIR2you's Avatar
New User
Default JDM TYPR-R ECU,in 00 US GSR w/ JDM R MOTOR???????
I bought a JDM Type-r motor & haven't put it in yet,but can I plug the JDM ECU right in or do I have to get a harness??? What can I do about my cruise control,..will I have to take it out??Please let me know??
Old Aug 3, 2001 | 08:57 AM
FAST94GSR's Avatar
New User
Default Re: JDM TYPR-R ECU,in 00 US GSR w/ JDM R MOTOR??????? (SIR2you)
the jdm ecu is programmed for the 100 octane gas they have over there. You're goin to have problem if not blow codes. Just get a reprogrammed ecu from someone here.
Old Aug 3, 2001 | 09:03 AM
Trey's Avatar
25 Year Member
Default Re: JDM TYPR-R ECU,in 00 US GSR w/ JDM R MOTOR??????? (FAST94GSR)
NOT TRUE!!!!!!!!
I have a 98 GSR with a 96 JDM ITR ECU. No codes and no problems. Experience is the key!
You will have bogging issues since the GSR is a dual plenum intake and the ITR is a single plenum intake manifold. Use the Skunk2 Intake manifold and you'll be all set.
Old Aug 3, 2001 | 09:06 AM
FAST94GSR's Avatar
New User
Default Re: JDM TYPR-R ECU,in 00 US GSR w/ JDM R MOTOR??????? (Trey)
ok if you say so, i have heard on this site that a jdm ecu didn't work. Ok I stand corrected.
Old Aug 3, 2001 | 09:12 AM
D's Avatar
D
cruise control is tied in to the tach signal and the VSS signal. i doubt you'll be changing those.
D
Old Aug 3, 2001 | 09:15 AM
JDM R98's Avatar
Default Re: JDM TYPR-R ECU,in 00 US GSR w/ JDM R MOTOR??????? (D)
what do you mean boggin issues..
Old Aug 3, 2001 | 09:24 AM
Benjamin Tang's Avatar
uh, he said he has a jdm type-r motor, not the original b18c1, so the secondary butterfly issues become redundant, unless he plugs it in right now without the engine swap.
i think the plugs will not match (2000 is obd3), and i'm not 100% certain the wires do either. i also don't know whether jdm and usdm error codes are the same.
i think the computer will retard timing w/regards to the hi-octane issue. jdm itr motors have higher compression pistons do they not? not sure if you will get peak performance. just run the highest octane u can in your area and don't skimp!
where's kenji? he would know this easy.
[Modified by Benjamin Tang, 6:48 AM 8/4/2001]
Old Aug 3, 2001 | 09:45 AM
JDM R98's Avatar
Default Re: JDM TYPR-R ECU,in 00 US GSR w/ JDM R MOTOR??????? (Benjamin Tang)
I have a JDM ITR motor I run like a 92 octane level..it fine with the 92
Old Aug 3, 2001 | 08:38 PM
Akira-R's Avatar
All you need to do is modify the harness cause you can't use the JDM harness.
You'll need an adapter to switch the plugs i think. I'm not sure cause yours is a 2000. But the obd1 plug on my95 had to be modified to fit the jdm plugs for the ecu. You'll have to use your GSR wireharness unless you buy a USDM ITR harness
cause the JDM one is configured to fit in an ecu on the other side of the car :-p
--reid
RevOnRacerz
Oct 27, 2005 12:30 AM
Maddox
Feb 27, 2005 06:56 AM
GripFactoR
Jun 21, 2003 11:00 PM
stiffiebdr
May 15, 2003 03:45 PM
