motor hesitation?
Old Jul 21, 2003 | 06:39 PM
magic hat #9's Avatar
Default motor hesitation?
my motor seems to have picked up an intermittent rough spot during idle. the tach does not move, but i can feel the engine shudder through the car. it happens randomly every 2-5 seconds (no unusual sound) and seems to have started after i took out the power steering. the motor is internally stock and has timing advanced to 18deg and a header & cat. i did a valve adjustment almost 1000 miles ago, but i haven't noticed anything until now. the shudder is very faint but definitely there. any thoughts on what could cause it?
Old Jul 21, 2003 | 06:42 PM
BlueR's Avatar
Default Re: motor hesitation? (magic hat #9)
hmmm...i assume its not throwing any codes, heh?
Old Jul 21, 2003 | 07:24 PM
vtec.dc2's Avatar
was power steering removed after valve adjustment? i'd try to re-check everything make sure nothing is loose or knocked of..
Old Jul 21, 2003 | 07:48 PM
Default Re: motor hesitation? (BlueR)
no cel. i can't imagine there would be any imbalance on the driveshaft with the p/s belt disconnected.
could poorly adjusted valves cause the motor to shudder intermittently? the motor sounds well adjusted and it was my 4th adjustment so i'm not a noob.
Old Jul 21, 2003 | 07:56 PM
Dr Pooface's Avatar
Check your plugs.
Old Jul 21, 2003 | 09:15 PM
nEoMuGen's Avatar
Default Re: motor hesitation? (Dr Pooface)
wild guess: battery? My car was doing that but the rpm moved. After I change the battery, it was gone.
EJ8_Man
May 4, 2016 09:26 PM
rcoolb2002
Jul 16, 2006 03:41 PM
Old School CRX Swap
Apr 23, 2006 10:42 AM
fipracing_com
May 31, 2004 09:15 AM
B18EG6
Jan 2, 2004 04:36 PM
