compresion test wows
Old Jul 21, 2003 | 05:32 PM
tintin11's Avatar
Default compresion test wows
Today i did a compression test on a H23 motor the numbers are 183 183 150 179.
The 150 is bad , besides from replacing the piston rings what other potions do i have. Can i adjust the valves ? i'm having the valve cover seal changed , timing belt , water pimp and balancing belt changed right now.
Still what do i do now ? besides getting a different motor or rings replaced
Old Jul 21, 2003 | 07:56 PM
judonoh's Avatar
did you try a wet compresion test? if you do this then it will tell you almost positively that the rings are bad. If the number change when doing the wet test then the rings are bad, if not then its something else. possibly valves.
Old Jul 22, 2003 | 07:54 AM
iakona's Avatar
yep. possibly valve seals or valve seats.
jc2801
27
Aug 25, 2015 08:22 PM
1sikhatch
Apr 26, 2007 02:22 PM
slowassciv33
Nov 20, 2006 08:25 PM
vxturbociv
Jul 23, 2006 06:27 PM
Yosshaa
May 23, 2004 11:55 AM
