B-series swap parts list
Old Jul 21, 2003 | 04:27 PM
civichopeful's Avatar
Default B-series swap parts list
A while back someone posted a very complete parts list for a B-series swap into an 88-91 civic. This parts list had all the part numbers from Honda included in the list. At the time I copied it and e-mailed it to myself but I can't find it now.
Does anyone recall this list or have the link to the website that it was on? Thanks
Old Jul 21, 2003 | 04:37 PM
RCautoworks's Avatar
Default Re: B-series swap parts list (civichopeful)
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
***** Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol"
Old Jul 21, 2003 | 05:29 PM
Default Re: B-series swap parts list (90blackcrx)
That would be the one 90blackcrx. Thanks for the list. It was driving me nuts because I could not find it.
Old Jul 21, 2003 | 05:32 PM
Your welcome
Old Jul 21, 2003 | 06:33 PM
Garrett's Avatar
if the Distributor of a b16a 90 is broken which one could we use?
Old Jul 22, 2003 | 11:23 AM
Default Re: (Garrett)
You could either get a dizzy for a 90 ls and cut one of the legs off, or you can use the inside parts of the dizzy from any civic around the same year. So like a 1990 crx dx inside parts would work and so would the si insides.
Old Jul 22, 2003 | 04:01 PM
Malgerus's Avatar
Default Re: (90blackcrx)
I don't think the dx would work, because it doesn't have some sensor or something like that..?
Anyways, about that list: Del Sol VTEC plug wires work really well too. And the shift linkage bitch pin can be 88-91 ED CRX/Civic.
Old Jul 22, 2003 | 04:30 PM
Audipwr1's Avatar
Default Re: (Mr. S)
any tips on how to remove that damn pin on the linkage it is the worst ever
do people usually just drill em and buy new ones?
Old Jul 22, 2003 | 04:58 PM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Water Pump 19200-P30-003 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol" </TD></TR></TABLE>
someones pimpin my list
Old Jul 22, 2003 | 10:54 PM
Default Re: B-series swap parts list (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">
someones pimpin my list </TD></TR></TABLE>
I got it off the resource, and about the bitch pin. I tried using one from the crx but it was to small, I ended up buying the one from an integra. And about the dx internals, some are interchangeable. Not saying the dx will have everything you will need but it does have somethings.
WindyIce
17
Nov 16, 2015 05:42 AM
Origin
Nov 3, 2003 07:56 AM
91hatchnewb
Apr 28, 2003 01:54 PM
bluecrxsi
22
Feb 25, 2003 04:47 PM
Monty
Sep 7, 2002 05:41 AM
