ITR rear sway bar on a Civic?
Old Jul 21, 2003 | 02:29 PM
SD_EM1's Avatar
Default ITR rear sway bar on a Civic?
just curious, will the the ITR rear sway bar (JDM or USDM, doesn't matter) work on a civic coupe? if so, what kind of modifications are necessary to make this part fit and work correctly? i tried a search last night, but i couldn't find anything. thanks in advance.
Old Jul 21, 2003 | 03:18 PM
poison's Avatar
Default Re: ITR rear sway bar on a Civic? (One Slow Civic)
You will need to get ITR rear LCA's in order to put it on. Other than that, it'll go right on.
Old Jul 21, 2003 | 04:45 PM
Audi RS4's Avatar
Lover
Default Re: ITR rear sway bar on a Civic? (poison)
and if you have a 96-00 civic the ITR LCAs will not fit...........they only fit on the EG......
*edit* you will need to get the Beaks upgrade to install a sway bar.....but I'm not 100% sure you can install the ITR sway bar with it
Old Jul 21, 2003 | 04:49 PM
poison's Avatar
Default Re: ITR rear sway bar on a Civic? (AK1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">and if you have a 96-00 civic the ITR LCAs will not fit...........they only fit on the EG...... </TD></TR></TABLE>
Correcto. CTR ones will fit though
Old Jul 21, 2003 | 04:59 PM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
Correcto. CTR ones will fit though </TD></TR></TABLE>
.............question....is the CTR sway bar as big as the ITR......wondering?
Old Jul 21, 2003 | 05:07 PM
poison's Avatar
CTR rear sway is the same size as the US ITR (22mm)
JDM ITR is 23mm I believe.
US ITR's pretty much have CTR 5 lug with ITR rear LCA's.
EDIT!!
My bad, I got it confused with the axle hub size
Old Jul 21, 2003 | 05:09 PM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">CTR rear sway is the same size as the US ITR (32mm)
JDM ITR is 36mm I believe.
US ITR's pretty much have CTR 5 lug with ITR rear LCA's. </TD></TR></TABLE>
awesome!!!!!!!!!!!!!
Old Jul 21, 2003 | 05:14 PM
poison's Avatar
awesome!!!!!!!!!!!!!</TD></TR></TABLE>
Check the edit, sorry bout that.
Old Jul 21, 2003 | 08:51 PM
Mr. Choi's Avatar
New User
all you need is a beaks kit the sway bar bushings endlinks nuts and bolts. since you have a civic SI all you need is the
bar bushings and a beaks kit.
SlowEJ8
Mar 28, 2009 05:10 AM
OneFire
Sep 3, 2004 11:06 PM
abolish415
Oct 3, 2003 12:08 PM
deviant1
17
Nov 3, 2002 11:40 PM
Jimmy L
Dec 29, 2001 04:22 PM
