O2 sensor question
Old Jul 21, 2003 | 02:09 PM
zdr262's Avatar
Default O2 sensor question
i have a race comming up this weekend and my honda o2 wont get in till next week so i found a ford o2 laying around the shop.... but i am a little confused on the wiring of the ford o2 it is a 4 wire o2 but it has a 2 white wires,a black wire,grey wire i was wondering which would go with each wire on the honda i know the yellow/blk wire is the heater but there is also a orange/blk stripe that turns into a solid black wire on the o2 side,,, a red/white wire that on the o2 side is a solid white,,,, and a blue/green that turns into a solid green on the o2 side...... sorry if it is a little confusing i was just in a hurry any help would be much appreciated........
Old Jul 21, 2003 | 02:22 PM
zdr262's Avatar
Default Re: O2 sensor question (zdr262)
ok if that was confusing cause after reading it myself it was kinda confusing my ford o2 sensor has 4 wires 2 white a grey and a black all solid....... well the colors on the honda wiring on the ecu side then on the o2 side as i can remember i just need help matchin them up.....ecu=yellow/blk stripe-o2 side=heater wire......ecu=orange/blk stripe-o2 side=solid black wire.......ecu=white/red stripe-o2 side=solid white..........ecu=blue/grn stripe-o2 side=solid green...... the last one i know its a sending wire but that damn ford is confusing is **** can somebody help me find which wires go to which from ford to honda and help would be appreciated thanks
Old Jul 21, 2003 | 02:41 PM
zdr262's Avatar
^ bump
Old Jul 21, 2003 | 03:29 PM
poison's Avatar
Ok I'm still confused after reading that several times...
What colors are on the ford o2?
2 white
1 grey
1 black
correct?
If that is the case:
White goes to Yel/Blk to A25 (Power Source)
White goes to Org/Blk to A6 (Heater Control)
Grey goes to WHT to D14 (O2 pinout)
Blk goes to Grn/Wht wire to D22 (sensor ground)
HTH
Old Jul 21, 2003 | 03:44 PM
zdr262's Avatar
Default Re: O2 sensor question (poison)
u r correct about the ford ones......im not sure where you r getting the green and white wire on the honda from.......... i am using the wires to the ecu they r yellow/blk i get that one, the orange/ blk i get that one to but then you say a white wire and green/white however my two other wires i have are a red/wht stripe and a blue/green stripe wires left................ does it matter which white goes where?
Old Jul 21, 2003 | 03:57 PM
zdr262's Avatar
ill look at the pinout 2 thanks for the info though i appreciate it.....
Old Jul 21, 2003 | 04:26 PM
poison's Avatar
Nope, white wires do not matter. As long as one is the Yel/Blk and the other goes to A6 (heater control).
Old Jul 21, 2003 | 04:40 PM
zdr262's Avatar
thanks for the info, i looked at the pinouts and it answered all my questions cheers to u....
Old Jul 21, 2003 | 06:50 PM
AzG35's Avatar
Try this http://www.boschusa.com/images...l.pdf
You need Adobe Reader to view it, but it shows how to wire up a O2 sensor from any OEM sensor.
Old Jul 21, 2003 | 07:30 PM
zdr262's Avatar
Default Re: O2 sensor question (AzSi22)
ok so what that is saying though is that the green wire should go to gray and white is supposed to go to black? ok ill try both ways cause poision said it was the other way around..... thanks if one doesnt work will it mess up the o2 sensor if i have them in the wrong place to start?
Old Jul 21, 2003 | 08:34 PM
zdr262's Avatar
gracias seniors
Tomina
Oct 14, 2014 11:04 AM
gsrjdm00
Engine Management and Tuning
Dec 9, 2008 05:57 PM
Ryanman
Jan 6, 2008 10:03 AM
vladd
Dec 5, 2003 08:42 PM
HXMan
Apr 26, 2002 08:13 AM
