Dilemma Im having with my 98 spec USDM itr motor *HELP*
Old Jul 21, 2003 | 10:25 AM
ScaleExtric's Avatar
Default Dilemma Im having with my 98 spec USDM itr motor *HELP*
Last night as I took my car out for a drive (after it been sitting for a whole month) and noticed a heatshield style vibration coming from where the Carsound Cat is . Only when it is cold though...when the car is heated up for about 15-20 min. the noise starts to gradually go away and get quieter and quieter.
The second problem I noticed was when the car is cold..and slightly warmed up...
I try to give it Steady throttle at about 18-2200 ..and when I try to keep it at those rpms..the motor starts to fluxuate the rpms from 1800-1000 back and forth.
However when the motor is FULLY warmed up..that problem goes away and has no problem keeping a steady throttle at 1800-2200
NOW this is the problem that occurs when the motor is fully warmed up..When I shift from 1st to second or 3rd...at around 4k rpms ..the motor lags really bad..as if the e brake was on.
Wth do you think it could be? A faulty sensor ? Clogged cat?
I not getting check engine light..so I cant check for any codes
Any of you guys experience this problem and can help a brother out
Thanks
Old Jul 21, 2003 | 01:12 PM
Default Re: Dilemma Im having with my 98 spec USDM itr motor *HELP* (ScaleExtric)
I guess I'm the only one that had these weird problems
Old Jul 21, 2003 | 01:20 PM
uNF$@#!'s Avatar
have you checked the usual items like plugs, plug wires, distributor, alternator...
if your thinking faulty sensor they usually throw up codes.
Old Jul 21, 2003 | 08:21 PM
Default Re: Dilemma Im having with my 98 spec USDM itr motor *HELP* (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the usual items like plugs, plug wires, distributor, alternator...
if your thinking faulty sensor they usually throw up codes.</TD></TR></TABLE>well, I am just curious..how this could happen so spontaneously. I am gonna check the plugs this weekend. Its just weird..how the problems fluxuate when the car is cold or hot.
Old Jul 21, 2003 | 10:18 PM
b18c-rDC2's Avatar
maybe its cuz thanh boosted that motor when he had it before it went into the car that you now own... jk
Old Jul 21, 2003 | 10:23 PM
fowler!'s Avatar
When was the last time you changed the fuel filter?
Old Jul 22, 2003 | 08:25 AM
NWPNOMORE's Avatar
Banned
Default Re: Dilemma Im having with my 98 spec USDM itr motor *HELP* (b18c-rDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c-rDC2 &raquo;</TD></TR><TR><TD CLASS="quote">maybe its cuz thanh boosted that motor when he had it before it went into the car that you now own... jk</TD></TR></TABLE>
lol
Old Jul 22, 2003 | 08:39 AM
Default Re: Dilemma Im having with my 98 spec USDM itr motor *HELP* (fowleryo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fowleryo &raquo;</TD></TR><TR><TD CLASS="quote">When was the last time you changed the fuel filter?</TD></TR></TABLE>since 1996 when the car was new
BLinindoll
16
Feb 26, 2013 11:29 AM
RSXMoneypit
Aug 27, 2012 07:28 AM
19prelude03
Jun 21, 2007 08:47 PM
typesnick
Apr 28, 2007 12:15 PM
RoofusX
Aug 23, 2001 06:31 PM
