Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
kill switch help, search included
Old Jul 21, 2003 | 08:46 AM
smokin rubber's Avatar
Default kill switch help, search included
ok well I have about a week to get everything together for the upcoming HC race at VIR. So naturally I have a bunch of **** to do including the install of a kill switch. I was going to have a local speed shop P1, do the install but they are currently booked, so I called up racer wholesale for the switch, and it just arived.
It is there switch 1, http://www.racerwholesale.com/...-Offs
hmm I hope I got the right one, I almost think I should have purchased the switch 4 http://www.racerwholesale.com/...-Offs
If you would be so kind as to look at this thread https://honda-tech.com/zerothread?id=190663, and scroll down 3/4 of the way, you can see the wiring diagram that was sent with the switch that I recieved.
The way I see this is tthat they want you to ground the main electrical feed through the resistor. Am I correct?
Old Jul 21, 2003 | 09:27 AM
Crack Monkey's Avatar
Default Re: kill switch help, search included (smokin rubber)
That looks correct. But I'm still not sure what the resistor is for? My RX-7 has two lines through the kill switch - the battery ground strap and the power lead from the alternator. The ignition is not switched in my setup - killing the alternator has the same effect.
Old Jul 21, 2003 | 09:45 AM
Honda318dx's Avatar
Default Re: kill switch help, search included (Crack Monkey)
Simplier than what is shown, I have had 0 problems the way I do it, so you have my IM..
Old Jul 21, 2003 | 09:47 AM
Willard's Avatar
W1 has an opening in the schedule.
Roberts works just fine.
Old Jul 21, 2003 | 10:04 AM
Backmarker's Avatar
How to wire:
Killing battery output: "Big wires"
1) Remove wire from battery to starter & discard.
2) Remove wire from battery to main fuse box & discard
3) Run wire from battery to kill switch
4) Run wire from "Output" of kill switch to starter and to main fuse box
Killing Ignition "Little wires"
1) Find power to coil (On EG it is black/yellow wire coming from ignition)
2) Cut wire and connect one end to one "2" terminal and the other to the other "2" terminal
Grounding alternator / fuse box "little wires"
1) Connect output side of "big terminals" (going to starter) to one terminal marked "1"
2) On other "1" terminal connect piece of wire to supplied resistor.
3) Connect other side of resistor to ground.
What happens: Stated simply as I can:
When the switch is "on"
- The battery is connected to the main fuse box through the switch.
- The power to the coil is connected to the distributor through the switch
- The resistor does nothing - it's not connected to either big terminal
When the switch is "off"
- The battery is no longer connected to the main fuse box
- The power is cut to the coil so the car stops running
- The main fuse box (and the alternator) are grounded through the resistor -preventing any voltage spikes from occuring.
The key thing is to make sure you connect the resistor / ground to the right side of the big terminals - you don't want to ground the battery by mistake.
Note that you never touch any of the alternator wires.
- Phillip
Old Jul 21, 2003 | 10:34 AM
Thanks everybody, I think all my questions were covered.
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
davidnyc
Jun 18, 2004 04:05 PM
Rhythm Racer
Jan 17, 2003 10:40 AM
iwhichisme
Sep 16, 2002 05:46 PM
