SWEET! :: massive oil leak
Old Jul 21, 2003 | 07:43 AM
prelittlelude's Avatar
Default SWEET! :: massive oil leak
yeah so last nite i was on my way to my girls house and noticed i hd no vtec, then i saw that my oil press gauge was bouncing all over the place so i decided toake it easy, went to bed got up started her had like 60 psi of press then as i drove it went down to 10 and slowlly made its was close to 0 YIKES! , luckly i made it to my work as it got to its lowest i immediatly shut her off
so i bend down and look the entire under body coated in mobil 1. ****
so i walk to the nearest cumbies and pick up 4 quarts of oil, i put three in and start it and bend down,,
its spewing out looks like right under the main crank pully , and i can see oil drips all down the timing belt cover .. HELP
anyone know of a common leak under there???
edit: DOH balancer shaft seal, crap!! never mind figured it out
anyone know the part number for that damn seal and the part they made to hold the seal in place im gonna need it!
Old Jul 21, 2003 | 08:21 AM
CHK4TIX's Avatar
Default Re: SWEET! :: massive oil leak (prelittlelude)
that sucks
Old Jul 21, 2003 | 08:42 AM
Default Re: SWEET! :: massive oil leak (CHK4TIX)
yep,, these are the part numbers i have found i think they are right
91233-PT0-003 seal
06923-P0A-306 retainer
Old Jul 21, 2003 | 08:56 AM
94vtecmn's Avatar
Don't forget new timing and balancer belts, you know they got coated with oil as well. And while your at it, if it's been a while since you replaced the water pump, it would be a good time to do that as well.
At least you noticed a problem before something catostrophic happened.
Old Jul 21, 2003 | 10:29 AM
Greyout's Avatar
Default Re: SWEET! :: massive oil leak (94vtecmn)
Honda has paid for new H22's before because of this, take it to a dealer
Old Jul 21, 2003 | 11:02 AM
94vtecmn's Avatar
Default Re: SWEET! :: massive oil leak (Greyout)
Yes, but you had to bring it back to them within a certain period of time, and that time they will cover it has expired.
Old Jul 21, 2003 | 12:47 PM
i found out it is b4 jan 1 of 2003 , ,, just alittle too late,, but i just did my timing belt and balancer belt and water pump, i asked the tech guy at honda if i should worrya bout the belts being coated and he said "just wipe them off"
Old Jul 21, 2003 | 12:53 PM
Steppin Razor's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">i found out it is b4 jan 1 of 2003 , ,, just alittle too late,</TD></TR></TABLE>
Call or write their customer service and see if they'll give it to you. It's a long shot, but if you word it right, you might get them to help.
Old Jul 21, 2003 | 12:54 PM
94vtecmn's Avatar
WHAT?!?!? Just wipe them off? Ouch......Glad you didn't take that advice.
Old Jul 21, 2003 | 10:29 PM
caLiH22A's Avatar
im curious to know what happens when the belts get oil all over them? does it cause them maybe slip, such as skipping.
Old Jul 22, 2003 | 08:13 AM
Default Re: SWEET! :: massive oil leak (caLiH22A)
i don't know what will happen im a bit afraid,, i needed my car bad so i only had time to rip it down and install the new seal and the block plate. i cleaned everything up really well, and both tthe belts seemed fine, as far as oil on the belts and them sliping im not too concerned because they are both toothed belts,
ryaldin
Jan 26, 2015 11:39 PM
Josueneta
May 7, 2010 01:43 PM
wangan
Honda Civic (2001 - 2005)
Jun 18, 2008 05:41 PM
The_Sober
Feb 25, 2006 06:23 AM
