cam gears wobbling??
Old Jul 20, 2003 | 09:28 PM
Tripz's Avatar
New User
Default cam gears wobbling??
while looking at my cam gear bolts (the bolt holding the cam gear to the camshaft right down the center) while the car is idling (700-750rpm), they appear to be wobbling or not centered?? is this normal?? thanks.
Old Jul 20, 2003 | 09:38 PM
J2turbo21's Avatar
Default Re: cam gears wobbling?? (Tripz)
That is not normal at all,who did the install?My crank pulley was doing that at idle and it did some serious damage to my crank.
Old Jul 20, 2003 | 11:19 PM
snowseeker's Avatar
Some Bolt heads are not perfectly centered, which will give a off center or wobble look when running. It wil not ruin the motor, unless you have a defective cam, crank, or if someone impacted them on for you than it might. Try a couple diffrent bolts and see if it straitens out.
Old Jul 21, 2003 | 12:02 AM
ek44's Avatar
buddy, i think thatz not normal.
the cam gear bolts should be centered or even spread out or
its gonna spin uneven - spinning down faster then spinning up (inertia).
please correct me if im wrong cuz im not sure.
Modified by ek44 at 6:24 AM 7/22/2003
Old Jul 21, 2003 | 12:21 AM
snowseeker's Avatar
Default Re: cam gears wobbling?? (ek44)
Ok, I'm wrong, all bolts in this world are machined perfectlly. So everyone better go out and check to see if there bolts are spinning nice and strait on there cams...
tapboyzlilj
May 29, 2007 10:30 PM
The Si
Feb 22, 2007 10:36 PM
Mugencrxsir1
Mar 2, 2006 02:55 PM
Infinite Auto
Apr 3, 2005 03:59 PM
B18Redline
Dec 2, 2004 07:01 PM
