problems with safc...im going to shoot myself
Old Jul 20, 2003 | 09:07 PM
Code Blue's Avatar
Default problems with safc and 550cc injectors ... im going to shoot myself
ok well long story short.
i got a revhard stage 2c turbo kit
turbo xs boost controller set at 10psi
a set of virens 550cc injectors with obd2 clips
trying to tune it with a afc
wired everything up, was so so ....felt like ****.....realized that one of the clips had a bad connection. (also noticed that on virens clips, the red wire seems to be always connected to the ground, while the yellow wire is connected to the signal wire, is that normal for these clips, i wasn't sure since the clips are ford, but they dont seem to fit the other way.)
after that i couldn't seem to get the damned car out of lean. it stayed there constantly. have a a/f gauge just for a general idea and always stayed on red.
smoked alot of the times when i was messing with the settings. tried almost every setting there was with no luck.
could the spark plugs be bad? i have bosch platinum +4's in there right now because im waiting on other plugs. but are there any plugs i could get from autozone ?
im really hoping i can figure this out. i took off the fmu and the map sensor check valve when i installed the afc. could that be a problem?
Modified by Code Blue at 4:20 PM 7/21/2003
Old Jul 20, 2003 | 09:15 PM
youngkow's Avatar
Default Re: problems with safc...im going to shoot myself (Code Blue)
Bosch plugs are bad, and I don't think you can lean out the 550's with the afc. You'll prolly need to get a 3 bar map sensor, and use that with the afc. Sorry I couldn't help much, but search. There are a lot of post here about this.
Old Jul 20, 2003 | 09:19 PM
Code Blue's Avatar
Default Re: problems with safc...im going to shoot myself (youngkow)
the problem isn't that i cant lean them out, its that no matter what i seem to do, its ALWAYS leaned out, its like im not running rich at all.
Old Jul 21, 2003 | 12:04 AM
safe driver's Avatar
what engine do you have?
is your CEL on?
what's your fuel pressure?
what are your afc settings?
if your a/f guage isn't bouncing back and forth, you have problems with your O2 sensor.
get some copper plugs. gap it to anywhere between .035-.025
most likely you are running too rich.
Old Jul 21, 2003 | 07:17 AM
Code Blue's Avatar
Default Re: (safe driver)
1.) b18b obd2
2.) my cel is always on, but i will reset and check it out
3.) stock fuel pressure
4.) i have tried all settings, from -50 to +20 doesn't make a difference
5.) a/f does not bounce back and forth, it stays at lean
6.) i think i might get some copper plugs today
Old Jul 21, 2003 | 07:53 AM
Code Blue's Avatar
Default Re: (Code Blue)
update: took the bosch platinum +4's out to check, the electrode has been burned off, so that could DEFINITELY be a factor, im going to try to go to autozone and fine some ngk zfr7f-11's to use.
Old Jul 21, 2003 | 09:05 AM
krazyDOHC's Avatar
autozone doesnt sell them ngk's ...pepboys does for about 10 bucs for 4
check the engine codes
you sure those injectors are clean and not clogged? ....code 16?
post your damn settings....
Old Jul 21, 2003 | 09:17 AM
Code Blue's Avatar
Default Re: (krazySOHC)
i got some new plugs
some ngk bcpr7es-11's im going to go try and get it with those. if it throws a code i will check it.
Old Jul 21, 2003 | 10:53 AM
Code Blue's Avatar
update: i got the plugs in, pretty much set everything at -50% hi/low and got the idle somewhat ok, but its still full rich under wot. doesn't throw a code, the a/f gauge goes back and forth now at idle. :next question
if i purchased a fpr (im thinking the aem) and turned down the fuel pressure from what it is now (which is stock) i could then lean it out a bit more correct?
Modified by Code Blue at 8:48 PM 7/21/2003
Old Jul 21, 2003 | 12:15 PM
Code Blue's Avatar
ttt1
Old Jul 21, 2003 | 12:24 PM
psileepR's Avatar
New User
with 550cc injectors i dont think you'll be able to trim enough fuel to prevent going rich up top.
only other option would be to turn up the boost but i think thats out of the question because around 11psi you'll get the map sensor code.
Old Jul 21, 2003 | 12:33 PM
Code Blue's Avatar
Default Re: (Civtek)
i couldn't turn down the fuel pressure via fpr?
Old Jul 22, 2003 | 02:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue &raquo;</TD></TR><TR><TD CLASS="quote">update: i got the plugs in, pretty much set everything at -50% hi/low and got the idle somewhat ok, but its still full rich under wot. doesn't throw a code, the a/f gauge goes back and forth now at idle. :next question
Modified by Code Blue at 8:48 PM 7/21/2003</TD></TR></TABLE>
you're better off ditching the 550s and getting 440-450cc injectors.
running too low of a fuel pressure is not good for the engine. (i think... someone correct me if i'm wrong)
atownludeh22a
Mar 13, 2011 08:36 PM
Evil EG
Apr 29, 2009 09:03 PM
Origin
Jan 30, 2004 07:27 PM
Sleepin'
Jan 31, 2003 02:03 PM
